Log spliter qustion
/ Log spliter qustion #1
CK732
Massy
I build a log spliter the way I wanted and I have 1 qustion. On the return line now it's a 1/2" I was thinking that's to restricted so I called for a price today on a 3/4" hyd. hose that was to hight so that got me
thinking black pipe3/4" would be much cheaper will I have any problems withit ?
/ Log spliter qustion #2
For a return line black pipe would be acceptable. Do not used galvanized since the oil will eventually cause the galvanizing to flake off and contaminate the system.
Depending on how the splitter is made you may need something flexible between the valve and reservoir to absorb flexing and vibration.
You should be able to find low pressure 3/4” hose at a reasonable price.
Thanks alot.
/ Log spliter qustion #4
Have you checked out premade hose at your local tractor store?
/ Log spliter qustion #5
pre-made on e-bay can be very inexpensive
/ Log spliter qustion #6
/ Log spliter qustion #7
Heck, i think most hydraulic lines on my tractor are only 1/2”.
/ Log spliter qustion #8
For the return line you do not need hydraulic high pressure hose , only oil compatible hose.
OK sounds good. Thanks!
Well I changed the line from 1/2" to 3/4" I bought a clear line and put it on and started the spliter and it spit fluid all over! .
I use hose clamps on each end I checked before starting the spliter I think I have to buy pex crimp rings and a better line.
/ Log spliter qustion #11
Get quality hydraulic return line and with proper barbed connector worm type hose clamps should be good.... THe hoses on my splitter wer 25 years old ans still good (I think) but in adding new engine and I decided to replace hoses and filter. Tha ias about 5 years ago, all is still good........
Also if you want top quality clamps go with "T" bolt...
Don't screw around with hardware/big box store crap....
I bought a 3/4" hyd. Hose all good now except oil filter I might have to change that because the gasket around it did not stop the fluid and it went on the floor.
/ Log spliter qustion #13
Now you know why it's just worth buying a hydraulic hose for a return line. 2gal of fluid prob cost the difference between low pressure hose and a hydraulic hose.
Surplus center is where I got all my 3/4 log splitter lines.
/ Log spliter qustion #14
Might look here... But my 22 ton splitter uses 1/2 inch hoses on pressure and 3/4 bulk onreturn sides....
Many of the 22 ton splitters only have 11 gpm pumps, and so it's normal to use 1/2" on high pressure side, 3/4" on low pressure side.
Most tractors flow a heck of a lot less fluid through their SCV and auxiliary lines, than a log splitter.
You want proper hydraulic lines for everything except the suction line between the tank and pump inlet. Assuming your filter is on inlet to tank, any line between the pump and filter can see some pressure, even if it's only super high between pump and cylinder. The suction line should be proper suction line, as regular unreinforced hose can collapse.
/ Log spliter qustion #15
Mine came with clear hose.
Use collar type clamps.
/ Log spliter qustion #16
Is it at least re-inforced?!?
The most popular clear tubing that is resistant to hydraulic oil would be clear versilon PVC plastic, which has a max pressure rating of only 30 psi at 72F in 3/4" ID... and burst pressure goes down with temperature.
There are hard (semi-flexible) clear plastic tubings, such as polyethelene tubing that has a pressure rating of 190 psi at 72F and a max working temperature of 180F, but this is still incredibly low for a hydraulic system. This essentially translates to a blown line anytime someone is a little lax on their filter change routine.
/ Log spliter qustion #17
No
There are no threads running through the tube.
It has stayed put for 10 yrs.
This is on a 16 tonner.
It is sufficient for the suction side of that splitter.
/ Log spliter qustion #18
No
I had thought you said low pressure side, which still sees positive pressure, depending on flow rate, viscosity, and filter condition. The pressure there should be relatively low, but it's still positive pressure.
But suction tube is another matter, that's actually at negative pressure relative to atmosphere. A suction tube may collapse inward, but will never blow out.
/ Log spliter qustion #19
Yes you are correct.
Low pressure return needs to be fitted hydraulic hose.
Had to read the op again.
There is pressure on the return line! It blew a hole in the clear line I had that why I bought a hdy. line it has 31 or 3200psi.
2011 Jeep Grand Cherokee AWD SUV (A61574)
2011 Jeep Grand...
2006 Ford Crown Victoria Sedan (A61574)
2006 Ford Crown...
Bobcat Pallet Forks (A64127)
Bobcat Pallet...
Hays LT-1 Tender (A61307)
Hays LT-1 Tender...
2015 Kenworth T880 QMC 8060R 40 Ton Tri Axle Straight Boom Crane Truck (A64194)
2015 Kenworth T880...
2015 Caterpillar 420F (A64126)
2015 Caterpillar...
