Log skidding cone
   / Log skidding cone #1
Chilly807
Elite Member
Nova Scotia
Kubota L3400DT
After pricing what it would cost to get one made, I decided to build my own. It's intended to fit over the end of a log, the choker extends through the nose cone to the hauling cable.
I built it from 1/4 aluminum plate, welded a piece of aluminum pipe inside the nose cone for reinforcement. It's 16 inches wide on each bottom edge, 2 inches at the top, and 18 inches high.
As it pulls through the woods, the cone keeps the log from hooking on trees, submarining under other logs, and keeps the cable from getting fouled in general. Ideally it would be round, but I don't have the gear to roll plate with, so the pyramid will have to do. I suspect eventually it may take a bit rounder form anyway...
Trials went really well this morning, it worked better than I had dared to hope! I skidded out two good size hardwoods, a birch and a maple that I had doubts the rope would handle.
I use a snatch block and 5/8 nylon rope, no winch in the picture as yet.
I made a point of not trying to clear the path, which was about 150 feet through trees and brush, uphill all the way. The maple was about 14 inches at the butt, just fit inside the cone.
It pulled both trees out without any snags at all, load on the tractor seemed lighter since the butt end of the log wasn't plowing it's way. No dents or other damage to the cone.
The picture quality isn't great (phone camera), I'll have to wait until the ground dries up a bit to get better pictures.
Chilly
   / Log skidding cone #2
Never seen one..interesting.
   / Log skidding cone #4
I am sure that I have seen vinyl cones at an equipment show. Looked like a great idea that sure saves a lot of rigging pulleys etc when the log hangs up.
   / Log skidding cone #5
I have never seen one of these, Very cool idea! :thumbsup:
   / Log skidding cone #6
Chilly.... why buy it when we can BUILD it.... yess... the pain of grabbing a hot piece of steel, the welding slag that fell into your boot, the pinched finger in the vice, the hammer marks on the back of your hand, the bloody shin from the corner of the bench..... AHHHHHH BUT LOOK AT WHAT I BUILT......... YESSS
   / Log skidding cone
I'll say this, if you use a winch or a snatch block to haul wood to the tractor, these are the cat's pajamas. Nice smooth hauls, no hang-ups.
Chilly
   / Log skidding cone #8
I found this somewhere and made one to use behind the atv. Works great and the cost was nothing.
2002 AMERITRAIL 32FT GOOSENECK TRAILER (A58214)
2002 AMERITRAIL...
JCB 507-42 TELESCOPIC FORKLIFT (A60429)
JCB 507-42...
2022 John Deere Z930M (A57148)
2022 John Deere...
2015 FONTAINE 53 DROP DECK (A55745)
2015 FONTAINE 53...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
SHOP MADE MANIFOLD TRAILER (A58214)
SHOP MADE MANIFOLD...
