lod splitter-farm all H
   / lod splitter-farm all H #1
ifishihunt
farmall h
I have a Farm all H. I just purhased a hydraulic log splitter for it. The splitter works fine, except for the fact that it will only split coffee can size logs. It is lach power for bigger ones. Any ideas? I know little about tractors, & less about hydraulics.
   / lod splitter-farm all H #2
pictures and dimensions would be nice
I will do that next time I get to my cabin. Someone told me The H does not put out enough pressure & I need to get a bigger ram.
   / lod splitter-farm all H #4
One source said the tractor had a max pressure of 850 psi.
Your tractor appears to have about 20 HP, so a Prince hyd pump would work, but at $500, it might not be worth it. Plus a larger cyl.
If you just installed a 4 in cyl with 2 in shaft, using the 850 psi, the force would be about 10,681 lbs, about 5 ton.
   / lod splitter-farm all H #5
I have a Farmall H, but if I wanted to put a logsplitter on it, I'd get a pto powered hydraulic setup for it. The hydraulic system is low pressure, and the pump is a little weak for that kind of work. At best, it will be slow.
   / lod splitter-farm all H #7
Should you get the pump above, and a 4 in bore cyl, with a 2 in rod, and 24 in stroke.
The extended force generated would be about 28,274 lbs, or 14 ton.
Extend time would be about 6.85 sec
Retract time would be about 5.1 sec
Total cycle time of -----------11.95 sec
   / lod splitter-farm all H #8
As others have stated, you are lacking not only in pressure but also GPM with a factory farmall H hydraulic system!
Go to the pto pump and tank of you are going to split with an H.
   / lod splitter-farm all H #9
For the cost that you would have invested in just making it "acceptable", you can get a pretty good stand-alone unit.
The ones you can buy @ TSC are pretty good. The huskee ones are just re-badged Speeco units and are good splitters.
I would possibly see about taking the 3PH unit back, and putting another few hundred with it to get a 20T standalone.
I dont know what you paid for the 3PH unit, or where you got it at, but TSC often sells the 20T units for $999
   / lod splitter-farm all H #10
If you are using the original H hydraulic system, it is feeble to begin with but also wears out quickly. In addition, it operates after the clutch. It was such a pain in the butt to drive the loader into the bank, shift to neutral so I could raise, then shift it into reverse so I could pull away. When it wore out to the point of being useless, we replaced it with a pump that fit between the distributor (we had replaced the original magneto with a distributor) and its drive. That gave full time hydraulics, something you won't have with any PTO driven pump on a H.
2024 John Deere 872GP Articulated Motor Grader (A52143)
2024 John Deere...
2015 Chevrolet Express Passenger Bus (A50323)
2015 Chevrolet...
2017 DITCH WITCH RT30 (A51243)
2017 DITCH WITCH...
Quick Attach 6' Snow Blade (A50515)
Quick Attach 6'...
2004 Ford E-250 Cargo Van (A50323)
2004 Ford E-250...
2024 AGT INDUSTRIAL HR-230 3-WHEEL LOADER (A51243)
2024 AGT...
