Tires Loading Tires w/BH attachment
/ Loading Tires w/BH attachment #1
Steve_Miller
Nova Scotia, Canada
2006 Kioti CK30HST
I was wondering if you load the tires with a hoe on the back, will this be a drastic problem or will you just have to stay out of the soft spots (no lawn work for my tractor). Reason #1 being that most of the time (approx 80% or more) the hoe will not be on the tractor. Reason #2 being that I will be towing my dump trailer and need the rear weight for loading. Does anyone have a rear weight built that will not interfere with the drawbar when trailering? Any suggestions?
Steve
Future Kioti owner (ordered Friday)
/ Loading Tires w/BH attachment #2
Almost without exception, every tractor we sell has the rears loaded with RimGuard. The few that aren't are a matter of customer preference, and most of them do not have loaders installed.
/ Loading Tires w/BH attachment #4
All of the last 5 tractors I have had have had backhoes and all have had loaded tires. I would not run an unloaded tractor unless all I did was mow lawns.
Andy
/ Loading Tires w/BH attachment #5
I have a 3 point mounted weight bracket with a trailer hitch on the back. Works great, don't have to worry about the trailer lifting up the tongue. Sorry no pics though...
/ Loading Tires w/BH attachment #6
I have a Kubota B7800 with loaded rear tires ("beet juice"). I have encountered no balance or other problems when my subframe mounted BH is attached. Because the BH weighs considerably more than any of my 3ph attachments other than the chipper/shredder, I think that the loaded tires are very important when you are using your FEL without the BH attached, and certainly if you are going to attach FEL pallet forks to it in order to carry heavy loads on the FEL.
If you analize the physics of it, they certainly don't aggrevate any "front light" condition even if your not using an FEL. If you have enough weight in the rear to lift the front of the tractor, it is going to pivot upwards on the rear tires. Since the rear tires themselves, where they contact the ground, become the pivot point, the loading in the tires on both sides of their contact point with the ground cancel out and the weight of the tires, whether filled or not, has no affect on the front lifting.
What loaded tires obviously DO affect, is the tendancy of a heavy load in your FEL to pivot the tractor on the front tires lifting the rear off the ground. Loaded rear tires and whatever attachment you have on the rear end, serve as the ballast that prevents this.
As far as performance on soft ground goes, my tractor with BH and FEL weighs in the neighborhood of 4000#. I doubt that the rear tires, which probably add 300#-500# at most, would have much affect on whether you are going to sink in, although in soft ground a tractor with loaded tires may do a bit more damage than without. However, since you are only adding about 10% to the weight of the rig, I doubt that there would be very much difference in the damage you do.
All in all, I think that the benefits of loaded rear tires far exceed any disadvantages, unless you are planning operate your tractor over your lawn frequently and in wet conditions. In that case, you might end up doing a bit more damage with loaded tires. Since you aren't planning on doing lawn work, the advanages of loaded tires are decisive.
