Tires Loading the tires
/ Loading the tires #21
I ended up paying $1.64 a gallon for WWF at Wally World. Today I was at the Dollar store and saw WWF for $1 a gallon. Thought I'd made a mistake, until I read the label : Good for temperatures down to 30 degrees Fahrenheit! This stuff must have more blue dye than alcohol.
/ Loading the tires #22
BigE_ said:
What am I missing here? Won't the water / WWF combo cause rust in the tire? I know rimguard isn't supposed to do this, but I thought you needed tubes for the WWF method.
-Steve
No rust. No tubes, just cheap rear weight that is an easy DIY:D
Brad
/ Loading the tires #23
-Steve
Remember that 1) wheels are painted so there is little exposed metal, 2) there is very limited oxygen in a loaded tire, 3) water and methanol are not very corrosive (unlike salts). Bottom line is that you would not expect anything more than a little cosmetic corrosion on wheels that are loaded without tubes when using water or WWF. RimGuard is the same. Despite it's name I don't believe there are any serious rust preventatives, it is just beet juice/sugar and those are not corrosive either. The term RimGuard was a clever marketing move to draw away some of the much maligned CaCl2 business.
2019 Mercedes-Benz Sprinter Box 1500/2500 Van, VIN # WD4PE7ED3KT012316 (A65563)
2019 Mercedes-Benz...
2017 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2017 Ford F-250...
3pt 55 Gal Rear End Boom Sprayer (A64127)
3pt 55 Gal Rear...
Spartan SRT-XD Zero Turn Mower (A66285)
Spartan SRT-XD...
more info coming soon (A61569)
more info coming...
New/Unused Quick Attach Pallet Forks (A65583)
New/Unused Quick...
