Tires Loading the tires
/ Loading the tires #21
I ended up paying $1.64 a gallon for WWF at Wally World. Today I was at the Dollar store and saw WWF for $1 a gallon. Thought I'd made a mistake, until I read the label : Good for temperatures down to 30 degrees Fahrenheit! This stuff must have more blue dye than alcohol.
/ Loading the tires #22
BigE_ said:
What am I missing here? Won't the water / WWF combo cause rust in the tire? I know rimguard isn't supposed to do this, but I thought you needed tubes for the WWF method.
-Steve
No rust. No tubes, just cheap rear weight that is an easy DIY:D
Brad
/ Loading the tires #23
-Steve
Remember that 1) wheels are painted so there is little exposed metal, 2) there is very limited oxygen in a loaded tire, 3) water and methanol are not very corrosive (unlike salts). Bottom line is that you would not expect anything more than a little cosmetic corrosion on wheels that are loaded without tubes when using water or WWF. RimGuard is the same. Despite it's name I don't believe there are any serious rust preventatives, it is just beet juice/sugar and those are not corrosive either. The term RimGuard was a clever marketing move to draw away some of the much maligned CaCl2 business.
2009 International DuraStar 4400 Fuel Tanker (A62613)
2009 International...
STIHL HT131 POLE SAW (A62613)
STIHL HT131 POLE...
2019 FORD F-350 SUPER DUTY (A65643)
2019 FORD F-350...
New/Unused Quick Attach Pallet Double Hay Spear (A65583)
New/Unused Quick...
International 490 Disc (A65640)
International 490...
Athey 7-12 Force Feed Loader (A62679)
Athey 7-12 Force...
