Loader wont hold position
/ Loader wont hold position #22
Piston seal leaking internally results in pressure intensification under load (explains creep down 6 inches then holding) the load is then not supported by the bore dia but rather the rod dia (less area = higher psi)
shifting valve during this condition results in relief valve blowing over (pressure is higher than RV setting) until intensified pressure is vented to return...thus load drops momentarily...
/ Loader wont hold position #23
Forgot to mention if not fixed this can lead to gland and/or seals seeing way to much pressure (possible blow-out):(
/ Loader wont hold position #24
I do not like to post this, because I know you will hate me even more ....:D....but I do it for the others, that are more patient with my posts....:thumbsup:
Nah, don't worry. I don't hate you at all. Matter of fact, I enjoy reading your explanations of how things work. Never too old or too smart to learn something. Keep up the great work.
Andy
/ Loader wont hold position #25
Andy
Some times it helps bring more information out, like a debate.:thumbsup:
Michelin Mach X BIB 710/70R42 Tires (A65640)
Michelin Mach X...
John Deere 5000-Series Tractor Grill Guard (A65640)
John Deere...
New/Unused Pallet of Webbing Slings (A65583)
New/Unused Pallet...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
New/Unused Wolverine 72in Quick Attach Ripper (A65583)
New/Unused...
Caterpillar D6N XL Crawler Dozer (A65579)
Caterpillar D6N XL...
