Loader wont hold position
/ Loader wont hold position #22
Piston seal leaking internally results in pressure intensification under load (explains creep down 6 inches then holding) the load is then not supported by the bore dia but rather the rod dia (less area = higher psi)
shifting valve during this condition results in relief valve blowing over (pressure is higher than RV setting) until intensified pressure is vented to return...thus load drops momentarily...
/ Loader wont hold position #23
Forgot to mention if not fixed this can lead to gland and/or seals seeing way to much pressure (possible blow-out):(
/ Loader wont hold position #24
I do not like to post this, because I know you will hate me even more ....:D....but I do it for the others, that are more patient with my posts....:thumbsup:
Nah, don't worry. I don't hate you at all. Matter of fact, I enjoy reading your explanations of how things work. Never too old or too smart to learn something. Keep up the great work.
Andy
/ Loader wont hold position #25
Andy
Some times it helps bring more information out, like a debate.:thumbsup:
(2) 30 Yard Roll Off Dumpsters (A65579)
(2) 30 Yard Roll...
2014 Frontier BB2060 Box Blade (A65640)
2014 Frontier...
John Deere 772-A Grader (A62679)
John Deere 772-A...
130 BBL VAC TRAILER (A63569)
130 BBL VAC...
2005 Freightliner Tropi-cal T396 39ft. Class A Motorhome (A64557)
2005 Freightliner...
2012 HEIL TRAILER (A65643)
2012 HEIL TRAILER...
