Loader wont hold position
   / Loader wont hold position #22
Piston seal leaking internally results in pressure intensification under load (explains creep down 6 inches then holding) the load is then not supported by the bore dia but rather the rod dia (less area = higher psi)
shifting valve during this condition results in relief valve blowing over (pressure is higher than RV setting) until intensified pressure is vented to return...thus load drops momentarily...
   / Loader wont hold position #23
Forgot to mention if not fixed this can lead to gland and/or seals seeing way to much pressure (possible blow-out):(
   / Loader wont hold position #24
I do not like to post this, because I know you will hate me even more ....:D....but I do it for the others, that are more patient with my posts....:thumbsup:
Nah, don't worry. I don't hate you at all. Matter of fact, I enjoy reading your explanations of how things work. Never too old or too smart to learn something. Keep up the great work.
Andy
   / Loader wont hold position #25
Andy
Some times it helps bring more information out, like a debate.:thumbsup:
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A52128)
Ditch Witch 6510A...
1995 FLEETWOOD BOUNDER S/A MOTORHOME (A51243)
1995 FLEETWOOD...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
2019 FORD F450 TOW TRUCK (A51222)
2019 FORD F450 TOW...
