Loader wont hold position
/ Loader wont hold position #22
Piston seal leaking internally results in pressure intensification under load (explains creep down 6 inches then holding) the load is then not supported by the bore dia but rather the rod dia (less area = higher psi)
shifting valve during this condition results in relief valve blowing over (pressure is higher than RV setting) until intensified pressure is vented to return...thus load drops momentarily...
/ Loader wont hold position #23
Forgot to mention if not fixed this can lead to gland and/or seals seeing way to much pressure (possible blow-out):(
/ Loader wont hold position #24
I do not like to post this, because I know you will hate me even more ....:D....but I do it for the others, that are more patient with my posts....:thumbsup:
Nah, don't worry. I don't hate you at all. Matter of fact, I enjoy reading your explanations of how things work. Never too old or too smart to learn something. Keep up the great work.
Andy
/ Loader wont hold position #25
Andy
Some times it helps bring more information out, like a debate.:thumbsup:
2019 VOLVO A45G OFF ROAD DUMP TRUCK (A65053)
2019 VOLVO A45G...
2011 FREIGHTLINER FLD120 FLATBED (A65643)
2011 FREIGHTLINER...
John Deere 2840 Tractor (A64047)
John Deere 2840...
78in Caterpillar Skidsteer Tooth Bucket (A65579)
78in Caterpillar...
2020 Cat 302.7D Mini Excavator (A64047)
2020 Cat 302.7D...
DMI Rear Bumper (A65640)
DMI Rear Bumper...
