Loader Vs, Big Dirt Scoop?
   / Loader Vs, Big Dirt Scoop? #21
I didn't mean to say the scoop has more capacity than the loader. I meant to say that I use the scoop and loader together to really increase my materials handling capacity. By the way, I do understand the $ factor. That's why I bought and used a $150 used scoop for a year and a half until I could afford the loader. Using a loader and mower together is not the point when I talked about aftermarket loaders. The point is that with loaders other than the 410, you will have to dissamble the entire loader subframe after you detach the loader, BEFORE you can attach the mower subframe parts. And then vice-versa. That is why the 410 is so superior and the aftermarket brands don't even warrent consideration in my book. If however I did not have or use a mid mount mower, then many aftermarket loaders are great pieces of equipment and I would consider purchasing one.
   / Loader Vs, Big Dirt Scoop? #22
<font color=blue>...I guess I should bail and get a small scoop now for a cheap price and save up my pennies for a FEL...</font color=blue>
Eureka...!
Best idea yet... you can talk about it for the next 6 months... -what, if, maybe, when, & how - or buy the cheapy and be using it to get some work done now... /w3tcompact/icons/blush.gif/w3tcompact/icons/wink.gif
   / Loader Vs, Big Dirt Scoop? #23
<font color=blue>...Also a 36 inch scoop will work well too on a normally aspirated 4100, but since my 4100 is , ..etc. ./w3tcompact/icons/laugh.gif</font color=blue>
Nuru, sorry if I missed this before, but what is the output of your turbo 4100? Or, if you haven't had it on a dyno, what is your best guess?
Thanks,
Bob
   / Loader Vs, Big Dirt Scoop? #24
There was a thread about all the uses of a loader with pictures and all. I could not find it, maybe someone else can.
Tell the scfo that you need it to do that whatever project she has been wanting you to do.
My wife wants new carpet. Anyone know a new implement that might help with that?
   / Loader Vs, Big Dirt Scoop? #25
CSAW,
Yep... either a scarifier or a cultivator to help remove the older carpet quickly!! /w3tcompact/icons/wink.gif
Terru
   / Loader Vs, Big Dirt Scoop? #26
I think he said he had 40 horsepower and in any case he has more horsepower than you, he,he.
I am going with a nitro system or supercharger. Actually, I have a source for a small 100 plus horsepower APU turbine engine, it weighs about 100 lbs, actually about 50 bare but I will need a reduction drive so I can lower output RPM to be compatible with my HST. I will use a Ford rear differential as the basis of the reduction. I will also install a diff locker from High Desert Products so I can lock all four wheels up like on my little 'oyota. I figure duals on the rear should also be helpful and about 500 lbs of ballast permenately set under the battery and subframe plus concrete in the wheels. I need a rear case from an L4600 if anyone has one laying about. Where should I place the air intake to the turbine, I built a particle seperator for a aircraft project once so that is the easy part. The exhaust may also be a problem, maybe I can use that to drive the seed spreader or--hey--- a hover tractor----yeah, yeah, now that is the ticket, a hover tractor, hmmmmmmm.
Oh, at flight idle that will be about 140 horsepower, constant RPM, nothing like the whine of a turbine, diesels are for wussies.
Wait, I could go turbine electric, buy a big generator at Home Depot and junk the Briggs and hook it up to the turbine and then get a big electric motor from an old commercial duty washing machine and hook that up to the HST. I think I am on to something here but I am going to have to reinforce that loader for sure.
J
   / Loader Vs, Big Dirt Scoop? #27
/w3tcompact/icons/laugh.gif/w3tcompact/icons/laugh.gif/w3tcompact/icons/laugh.gif
J...................
.......Can I quote you on that....? /w3tcompact/icons/grin.gif
   / Loader Vs, Big Dirt Scoop? #28
<font color=blue>...The exhaust may also be a problem, maybe I can use that to drive the seed spreader or--hey--- a hover tractor----yeah, yeah, now that is the ticket, a hover tractor, hmmmmmmm.
Oh, at flight idle that will be about 140 horsepower, constant RPM, nothing like the whine of a turbine, diesels are for wussies.</font color=blue>
Mark Chaukley.. Red Alert.. Red Alert!!! We may have someone here who is challenging your status as Most Extreme Modifier of Equipment! LOL! /w3tcompact/icons/laugh.gif
   / Loader Vs, Big Dirt Scoop? #29
<font color=blue>... I figure duals on the rear should also be helpful and about 500 lbs of ballast permenately set under the battery and subframe plus concrete in the wheels. ..</font color=blue>
J,
This is that secret project that Kubota commissioned- you're doing on the Kubota BX before the brother-in-law gets it... right...? /w3tcompact/icons/wink.gif
   / Loader Vs, Big Dirt Scoop? #30
<font color=red>...Red Alert.. Red Alert!!! ...</font color=red>
Bob...
Nuru will need this alert if he spends $800 for that 60" wide 3-point Dirt scoop... and then tries to use it... FULL...! /w3tcompact/icons/blush.gif
2017 Ford F-750 Crew Cab Terex Hi-Ranger 6TC-65 65ft Insulated Bucket Truck (A56858)
2017 Ford F-750...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52707)
2007 CATERPILLAR...
2016 Chevy caprice (A55788)
2016 Chevy caprice...
1087 (A58374)
1087 (A58374)
2014 RAM 2500 (A58214)
2015 Chevrolet Silverado (A56858)
2015 Chevrolet...
