Loader Valve Lost Float
/ Loader Valve Lost Float #1
Dallas_Lilly
Flagstaff AZ
Montana 4340C
I have the curved boom loader on a 3040 and recently I have lost the float position, it kinda worked if you forced it for a while and now it doesn't work at all. I didn't have time to do anything with it and then we got 4 feet of snow. I now have lost float all together and it goes down really slow.
Has anybody else had this problem? or does anybody happen to have a parts breakout for that valve?
Thanks,
Dallas
/ Loader Valve Lost Float #2
I sounds to me like your joystick control is loose. Lift the boot up and check out where the joystick lever pivots and pushes / pulls the control spools. If something is loosening off then you are loosing stroke. With less stroke you are not reaching the detent position for float. Probably a very easy fix.
Thanks, i will check that when I get home from work, that would make sense because I noticed too that it was leaking some fluid under the boot.
ALLMAND MP65-8E1 PORTABLE (3) PHASE GENERATOR (A63276)
ALLMAND MP65-8E1...
2018 Ford Fusion Hybrid Sedan (A64557)
2018 Ford Fusion...
2024 Ranger 1500 Extreme Duty North Star (A62679)
2024 Ranger 1500...
2026 Electric Tricycle (A64194)
2026 Electric...
Landhonor 8" Mini Excavator Bucket (A66285)
Landhonor 8" Mini...
Wilbeck 2109 12ft. Digger Disc Chisel (A65640)
Wilbeck 2109 12ft...
