Loader Valve Lost Float
/ Loader Valve Lost Float #1
Dallas_Lilly
Gold Member
Flagstaff AZ
Montana 4340C
I have the curved boom loader on a 3040 and recently I have lost the float position, it kinda worked if you forced it for a while and now it doesn't work at all. I didn't have time to do anything with it and then we got 4 feet of snow. I now have lost float all together and it goes down really slow.
Has anybody else had this problem? or does anybody happen to have a parts breakout for that valve?
Thanks,
Dallas
/ Loader Valve Lost Float #2
I sounds to me like your joystick control is loose. Lift the boot up and check out where the joystick lever pivots and pushes / pulls the control spools. If something is loosening off then you are loosing stroke. With less stroke you are not reaching the detent position for float. Probably a very easy fix.
Thanks, i will check that when I get home from work, that would make sense because I noticed too that it was leaking some fluid under the boot.
2009 PALFINGER 11 FT SERVICE BODY (A62613)
2009 PALFINGER 11...
2016 Nissan Altima Sedan (A61574)
2016 Nissan Altima...
2012 Ford E-350 4x4 Terra-Hawk Mobile Surveillance Van (A61573)
2012 Ford E-350...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
2018 Bobcat E35i Mini Excavator (A61572)
2018 Bobcat E35i...
