loader swap
/ loader swap #21
Thanks J_J, I always learn something in your replies. I do not need the knowledge, but will store it in my memory. The trick will be retreaving it!!
/ loader swap
Update...both recommended valves were not available JJ. so I went ahead and mounted the larger control valve . spoke with the vice president of surplus center and he told me that Valve would probably work on a closed Center system . so far so good still have to bleed more air out of the system and do some welding on the brackets I fabricated . hope to finish it up and test it out next week ;thanks to all who chimed in it meant a lot .
/ loader swap #23
Which valve did you end up with, and did you order the closed center plug?
/ loader swap
It was a 25gpm valve and a I ordered a closed center plug for it.
/ loader swap
Just a note of gratitude to JJ, Tx Jim, and all others for your guidance. It has been two long years and several thousand dollars since I first brought home the caseIH 585 with bad hydraulics. That tractor not sits in the back forty with a bushhog. The loader happily resides on my JD 2020. I cannot begin to express the joy I felt carrying two round bales across the pasture yesterday...thanks a million guys.
/ loader swap #26
Thanks for reporting you progress and CONGRATULATIONS.
CASE IH MX220 MAGNUM TRACTOR (A57192)
CASE IH MX220...
UNUSED FUTURE FT-RP72 - 72" HYD ROCK CRUSHER (A52706)
UNUSED FUTURE...
Case SV280B (A60462)
2015 Nissan Altima SV Sedan (A59231)
2015 Nissan Altima...
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A61307)
2021 Takeuchi...
2020 GENIE GTH-5519 TELESCOPIC FORKLIFT (A59823)
2020 GENIE...
