Loader Spool: Identical circuit upgrade from Ansung 17004 (2 spool) to 3 or 4 spool
   / Loader Spool: Identical circuit upgrade from Ansung 17004 (2 spool) to 3 or 4 spool #11
Youre good. The "T" I was referring to/ thinking of adding would connect to the first spool's T- line which goes back to the tank [to the T-line of the second spool. I don't think I would have to upsize that line as only one spool should be running through the T-line at a time that leads to the tank; correct?
Thanks
Yep that's right.
No matter if the flow to the tank is from one valve or two, it can only be as much as the pump puts out.
Well, I've searched for some time and I cannot find any information on this spool.
It is made in Italy, and the number looks like DOGDF2AACCZ150004
3044668
15/04/03
Any help would be appreciated. Thanks
   / Loader Spool: Identical circuit upgrade from Ansung 17004 (2 spool) to 3 or 4 spool #13
Very similar but made in Turkey,
good luck in your search.
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
2018 MQ POWER WHISPERWATT DCA-25 GENERATOR (A58214)
2018 MQ POWER...
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
Rooster Weathervane (A55853)
Rooster...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Volvo A40D Off Road Dump Truck (A56438)
Volvo A40D Off...
