Loader Question
Status
Not open for further replies.
/ Loader Question #1
JordanMarina
I have a 1988 Ford 2120 tractor with a Bush Hog 2246 loader. I need the loader to lift about 200 more lbs. Can I put bigger hydraulic cylinders on it or increase pump pressure? Or do I have to buy a different loader? Thanks for any help.
/ Loader Question #2
I don't know how you have the tractor set up, but if you don't have sufficient counterweight on the 3pt hitch, you're missing out on some more lift.
Make sure you have several hundred pounds on the back, and the loader can lift more, up to it's max.
Mine requires something like 650# or more on the rear to get max lift.
Now if you have sufficient weight, I'll defer to the hydrualics guys to answer about changing things out.
I will say though that the engineers that designed the loader didn't intend it to handle heavier loads and that's why it has the equipment that it does. Adding more to the max could end in damages.
John
/ Loader Question #3
Increasing the pressure would do the trick. There should be a relief valve in your valve block that could be adjusted. That said, there is a capacity to everything. Usually there is a bit of reserve built-in but you'll have to find the limit the hard way.
/ Loader Question #4
Duplicate of this thread.
Forum Rule 2. Do not cross-post your message to multiple forums.
Thread closed.
Status
3012SFL (A61567)
3012SFL (A61567)
NEW, ATS Mini Excavator (A62679)
NEW, ATS Mini...
2021 Gehl RT215 Track Loader with 74in Smooth Bucket (A63689)
2021 Gehl RT215...
Mini rock grapples (A61567)
Mini rock grapples...
2021 Weber CF 2-IIHD Plate Compactor (A61572)
2021 Weber CF...
DRILL CABINET SKID (A60736)
DRILL CABINET SKID...
