Loader Question
Status
Not open for further replies.
/ Loader Question #1
JordanMarina
I have a 1988 Ford 2120 tractor with a Bush Hog 2246 loader. I need the loader to lift about 200 more lbs. Can I put bigger hydraulic cylinders on it or increase pump pressure? Or do I have to buy a different loader? Thanks for any help.
/ Loader Question #2
I don't know how you have the tractor set up, but if you don't have sufficient counterweight on the 3pt hitch, you're missing out on some more lift.
Make sure you have several hundred pounds on the back, and the loader can lift more, up to it's max.
Mine requires something like 650# or more on the rear to get max lift.
Now if you have sufficient weight, I'll defer to the hydrualics guys to answer about changing things out.
I will say though that the engineers that designed the loader didn't intend it to handle heavier loads and that's why it has the equipment that it does. Adding more to the max could end in damages.
John
/ Loader Question #3
Increasing the pressure would do the trick. There should be a relief valve in your valve block that could be adjusted. That said, there is a capacity to everything. Usually there is a bit of reserve built-in but you'll have to find the limit the hard way.
/ Loader Question #4
Duplicate of this thread.
Forum Rule 2. Do not cross-post your message to multiple forums.
Thread closed.
Status
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
2008 GMC 3500 HD 4x4 Ext. Cab 9Ft. Flatbed Truck (A64194)
2008 GMC 3500 HD...
2014 VOLVO A40G WATER TRUCK (A65053)
2014 VOLVO A40G...
2013 International 4300 Bucket Truck 55' (A62613)
2013 International...
Kubota V3300-T-E2BG Turbo Diesel Engine - 3.3L - Pump Takeout - Tier 2 (A63689)
Kubota...
2005 Chevrolet Silverado 3500 4x4 Crew Cab Pickup Truck (A64194)
2005 Chevrolet...
