Loader Problem
/ Loader Problem #1
Jackrabbit_Slim
B.C. Canada
B2710
I've noticed on my last couple of outings that the LA401 loader on my B2710 has been a little "slow" when dumping. Not as responsive as I'd like. This afternoon I noticed a slight catch as I moved the stick over. Nothing I couldn't move past with just a little more pressure, but a definite catch.
My first thought when things were just "slow" was that I might have a valve partially plugged. This catch, however, feels mechanical.
So, it's pouring rain here, I don't have a shop, and I'd like to make the fix as quickly as possible. ie. If I'm going to need parts, I'd like to pre-purchase... my dealer is always happy to take them back. Where would the smart people start to look on this one?
Thanks,
Slim
/ Loader Problem #2
Do you have guage for hyd pressure? Might be a way to see if it's a flow or mechanical problem(hi press). Compare curl and dump functions. I'd probably grease it too, just for peace of mind.
/ Loader Problem #3
Assuming you have a joy stick, and you have a "catch" or the stick is binding and its mechanical (possibly) I would pull the weather boot off of/ or slide up on the wand and lube the linkage to your hydraulic spools, since the linkage is suposed to operate like a "cv" or "u" joint and present oportunities to hang up. Check this before you worry or order parts. Hope this helps. /forums/images/graemlins/grin.gif
/ Loader Problem #4
Since you mention the slight catch I may be off base with this one, but have you considered a temperature issue. My loaders are definately slow until the fluid warms on cold days. Whats the temp outside there?
Andy
20704 (A55853)
20704 (A55853)
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
2007 DELTA GOOSENECK TRAILER (A58214)
2007 DELTA...
ULTRAQUIP LIGHT TOWER (A60736)
ULTRAQUIP LIGHT...
2015 Volkswagen Golf Hatchback (A60352)
2015 Volkswagen...
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A58214)
2014 MAGNUM...
