Loader Problem
/ Loader Problem #1
Jackrabbit_Slim
B.C. Canada
B2710
I've noticed on my last couple of outings that the LA401 loader on my B2710 has been a little "slow" when dumping. Not as responsive as I'd like. This afternoon I noticed a slight catch as I moved the stick over. Nothing I couldn't move past with just a little more pressure, but a definite catch.
My first thought when things were just "slow" was that I might have a valve partially plugged. This catch, however, feels mechanical.
So, it's pouring rain here, I don't have a shop, and I'd like to make the fix as quickly as possible. ie. If I'm going to need parts, I'd like to pre-purchase... my dealer is always happy to take them back. Where would the smart people start to look on this one?
Thanks,
Slim
/ Loader Problem #2
Do you have guage for hyd pressure? Might be a way to see if it's a flow or mechanical problem(hi press). Compare curl and dump functions. I'd probably grease it too, just for peace of mind.
/ Loader Problem #3
Assuming you have a joy stick, and you have a "catch" or the stick is binding and its mechanical (possibly) I would pull the weather boot off of/ or slide up on the wand and lube the linkage to your hydraulic spools, since the linkage is suposed to operate like a "cv" or "u" joint and present oportunities to hang up. Check this before you worry or order parts. Hope this helps. /forums/images/graemlins/grin.gif
/ Loader Problem #4
Since you mention the slight catch I may be off base with this one, but have you considered a temperature issue. My loaders are definately slow until the fluid warms on cold days. Whats the temp outside there?
Andy
2016 FORD F550 CREW CAB SERVICE TRUCK (A59905)
2016 FORD F550...
2004 Mack CL713 Tri-Axle Heavy Haul Truck, VIN # 1M1AD64Y04M001417 (A61165)
2004 Mack CL713...
BUNDLE OF 10' RE BAR (A62131)
BUNDLE OF 10' RE...
Crabtree 17yd Dirt Scraper (A64047)
Crabtree 17yd Dirt...
2017 Genie GTH-636 (A62177)
2017 Genie GTH-636...
2020 14ft. Continental S/A Boat Trailer (A61569)
2020 14ft...
