Loader mounted snow blower
/ Loader mounted snow blower #81
You're supposed to do maint. on slip clutches?! My bush hog was 20+ years old when I sold it and I think I might have pressure washed it in the fall and always lubed as needed...never touched the clutch and it worked fine when I hit something too big to cut. Freezing of water in the clutch could be a problem though.
Leon,
More ideas! #2 son wants belts and not chains, but then he's not building it.
Yup, every year. The clutches freeze up with rust.
This year I loosened up all the bolts & springs holding my clutch together so there was 0 spring pressure. Jammed a 2x4 into the tines & fired up the tractor. When I engaged the PTO there was a big bang & the tines dug 2" into the 2x4. So just rust & what not was holding that clutch together enough to transmit a lot of power. A 2" gash into some decent wood powered by nothing but rust is pretty bad. Add in spring pressure & it will never slip.
After freeing things up I tightened all the bolts down 2 turns after finger tight (manual said 2.5 turns). It doesn't slip under normal operation & I can tighten it up as needed if it does.
Those clutches, at least from King Kutter end up being a bit to tight so they don't slip when expected. Add to that a year or more of rust & you'll get a clutch that is so tight & locked up it will never slip. At that point you hope your PTO shaft grenades when things jam rather than internals on your tractor.
Clutches are nicer if you need a lot of protection, but maintenance is a bit of a pain. Sheer pins are 0 maintenance unless you pop a lot of them. Then the extra scheduled maintenance on the clutch is easier than randomly replacing lots of pins.
/ Loader mounted snow blower #82
Clearly, I've never done that to slip clutches. I think the one on my bush hog had fiber plates that slipped and nothing to rust that I recall.
Nothing wrong with shear bolts on Summer equipment but it's terribly cold fingers that need to work on snow blowers in the Winter...don't like it at all. Slip clutch be good!!
/ Loader mounted snow blower #83
My King Kutter tiller has a metal plate on each side with a clutch material in the middle. Those metal plates rust & stick to the clutch material. Even here in Colorado which doesnt have much humidity, not desert dry, but still low humidity. 1 year of rust & 0 spring pressure transmits enough power to put a 2" gash from a tiller tine into wood this year, which is about par for the course in the 3 years ive owned it.
I have the other style of cluth that isn't heald together by bolts & springs. It's frozen to my pre-owned 3pt trencher & I havent pulled it appart to see how it works. Pretty sure it has similar metal plates & a clutch disk in the middle & will suffer from the same issues. Every PTO clutch manual ive seen perscribes basically the same annual maintnance.
/ Loader mounted snow blower #84
Thanks Fallon. I'll look into it.
Parker is a nice area by the way.
/ Loader mounted snow blower #85
While bouncing around on my Suzuki DRZ 400 on some back trails near the house I wondered if something like that engine and transmission could withstand the stress of throwing snow. It's a 28 hp with 5 speed chain drive transmission and manual clutch. It will run all day at 5K rpm and never whimper but I wonder if it would stand up to the shock of hitting something like ice in the snow? Maybe not a chain drive between the transmission and blower or maybe a cog belt.
Thoughts?
/ Loader mounted snow blower #86
Hello Lowrider2120,
The right angle gearbox has 540 rpm coming in to it from the tractor and then it is transmitted to the worm gearbox or the chain drive for the cross auger depending on how your snow caster is set up.
if you use this engine your going to need 9 to 1 reduction to be on the safe side of things if you use high idle where with the V 4 Wisconsin your going to have less of an issue with its high idle setting by using 2 row chain to power the gearbox.
I guess I would still check with a tractor graveyard in the Magic Valley or close by to find a power unit and then swallow hard when you start checking on prices for matched equal size cog belts and cog gears to provide you with 540+rpm at the gearbox as the cogs would have to be the same size to provide 540 RPM to the gearbox. I have only dealt with Cog belts and gears that were matched sets for Gardner Denver 2 piston air compressors that were driven by Duetz inline 4 and 6 cylinder air cooled engines.
Your going to need a very large pair of cog gears to do this but it could be done with a Wisconsin engine that would be just loafing along.
I will have to check what size cog gears you would need for this.
Changing worn out cog belts is a breeze with an open end wrench to remove the side plates, all you would need to do is fabricate a box to cover the cog belt to keep it out of the weather and secure it with spring pins and cotter pins so you can just lift it out of the way to change the cog belt.
Lots of rotary lobe blowers depend on smaller cog belts and cog gears to drive them. I will post what I find out.
/ Loader mounted snow blower #87
Sorry..sould have mentioned that 5K rpm is engine speed, not what comes out of the transmission depending upon what gear is chosen. I don't know the ratios but I would guess that 4th gear would come close to 540 so it could be maybe close to 1 to 1 on the belt drive. Do you think amotorcycle transmission would hold up to snow throwing?
/ Loader mounted snow blower #88
I can not help you much until much until the engine is mounted and properly lined up on the snow caster or a plate welded to the top of the quick hitch to mount the engine. Sprockets-if used need to be installed and lined up before the chain length can be measured. The roller chain drive method with an idler sprocket witha rubber shock mount on the top section of roller chain would be be the all weather choice for a snow blower.
Once the engine speed is known for the 540 rpm PTO shaft snow blower speed the sprocket size needed can be quickly determined.
/ Loader mounted snow blower #89
I was looking at sprockets today at a farm store...must be dozens of combinations to get to the right input RPM. I think I'd like to run engine at about 80% to get to somewhere around 540.
Started welding mounts today...won't take long once I get the time to spend on it.
/ Loader mounted snow blower #90
Once you have the engine mounted all we have to do is some math to get the correct diameter sprockets and the chain size you want to use.
It would be easy enough to use a ribbed timing belt drive as a final drive where the chain drive would only have to connect to the first timing belt pulley and the timing belt sprockets
would be sized for 540-600 rpm from the driven sprockets speed.
/ Loader mounted snow blower #91
QD plate is attached to the blower.
So...chain and sprocket with no clutch...right?
/ Loader mounted snow blower #92
No clutch needed. Having either a secondary chain drive or a timing belt in a vertical mounting
to let the drive chain stay on a horizontal path would be best as the power train would not be
stressed by a long single row roller chain. In that way you can use a rubber torsion arm tensioner sprocket
to keep the chain working properly without having to worry about chain slack bouncing or an idler sprocket
sprocket on the top or under the top of the chain loop to maintain the proper tension.
What ever you do be sure to invest in the 60H or 80H roller chain with the cotter keys in every link they are the best ones as you can use a long cotter key to replace them when you have to repair a chain break as they do not need a roller
chain breaker but you will need a roller chain stretcher in your tool box. You should purchase the H roller chain as its heavier and thicker and the H sprockets as well. With any luck you will have to buy one box of roller chain and a herd of repair and half links for your tool box.
/ Loader mounted snow blower #93
I was planning on 80 and it looks like 9 tooth driven at 2700 rpm and 45 tooth on the blower for 5:1...or roughly 540 rpm...sound right?
/ Loader mounted snow blower #94
I have to check the math formula first.
Using the formula I have
2,700 rpm
9 tooth drive
45 tooth driven
80H chain will be stronger and of course last longer with the idler sprocket.
input 2700 rpm
output is 540 rpm
You need to find the exact center to center distance before we can proceed further so the you can position the tensioner to maintain passive tension on the upper chain strand with a rubber torsion arm mounted sprocket.
the next thing is mounting the 1 row or 2 row sprocket on the crankshaft.
/ Loader mounted snow blower #95
That's what I got too.
I think the center to center distance must be at least greater than the sum of the 2 sprockets which are roughly 3" and 10". I'm guessing it will be at least 18" so I should be OK.
Need to save my allowance so I can get an engine.
/ Loader mounted snow blower #96
Save my sanity please and buy the two row cottered 80H chain and a rubber torsion arm idler sprocket please as you will have a huge amount of torque you have corral at all speeds.
/ Loader mounted snow blower #97
OK!...I need to keep what little bit of sanity that remains in my little pea brain.
/ Loader mounted snow blower #98
From experience I can advise U that chain stretches so you will want to have some sort of tensioner device in that loop.
I used #40 with a 16 hp 0n a 48" blower and that chain stretched in the 1st 3-4 hrs of usage.
Just my HMO .
/ Loader mounted snow blower #99
Thanks...I'm with you Piloon. I'm planning slotted mounting holes for the engine to allow for the adjustment to deal with chain stretch. I'm an old motorcycle guy and very familiar with care and feeding of chain driven stuff.
/ Loader mounted snow blower #100
Bonjour Mon Ami Piloon, hello lowrider,
Piloon, that is why I suggested the rubber torsion arm to support the free wheeling
2 row 80H sprocket.
All low rider has to do is bolt the engine to motor mounts and he will not have to worry
about having to slide the engine back and forth where the rubber torsion arm will keep
adequate tension on the tow row chain at all times and when the slack gets really bad
he can take a full link out and add back a half link without moving the power unit.
The rubber torsion arm maintains pressure on the roller chain and avoids any chain
bouncing and having the chain bounce off the sprockets at any time.
Leon
Landoll 18' Tilloll (A66285)
Landoll 18'...
2016 Jeep Compass SUV (A64557)
2016 Jeep Compass...
2013 INTERNATIONAL DURASTAR 4300 M7 SWEEPER TRUCK (A63276)
2013 INTERNATIONAL...
2015 International WorkStar 7500 T/A Forestry Grapple Truck (A64556)
2015 International...
100 Manure Spreader (A66408)
100 Manure...
New Holland 675 Manure Spreader (A66408)
New Holland 675...
