Loader mounted snow blower
/ Loader mounted snow blower #21
What about a rear mount pull snow blower. There is one on the quick attach website from the earlier link. I don't think these get enough credit. I've seen a Canadian contractor do about 3500 driveways with 26 tractors in about 5 hours. I mean they can be super quick. Of course this is really tight routes and may even be home owner associations where they are doing all of them in a neighborhood, but still mighty impressive. There is a lot of talk on this site that if you drive over the snow first it packs it down and then the blower doesn't get all of the snow up, but to be honest I haven't seen any implement (except a power broom) that gets all of it up.
Yeah. Not even considering a rear mount. Too much twists and funds to back down(and too steep). Also a pull style would just leave me packing everything thing 1st
/ Loader mounted snow blower #23
The only other real option you have is to go into debt and
upgrade or purchase a Motorised UTV/RTV snow caster
and hope the 27 horsepower the largest model has is enough.
(it will not)
The other issue is these snow casters will require you to have
an equal weight on the rear with loaded tires and road grader
or log skidder chains snow chains.
/ Loader mounted snow blower #24
Bradbilt, I have a rear pto pump/ resovour on a b3350 with only 27 ish hp at pto. I tie wrap hoses under the frame up to the fel. Haven't figuried a better way for hoses. I use 3/4 inch hose everywhere and have teed in a pressure guage at the pump. When blowing in 14 inches of snow, if I drove to fast, the pressure would go up and the pump would load down my tractor engine. ( The pump maximum input is 33 hp) I was running around 2200 rpm as I'm still under my first 50 hours so some less than the 27hp. Pick a big enough pump (gpm rating) for the blower you get and ignore hp. You may have a slow forward speed, but the blower will blow if you maintain gpm thru motor. Mine is on a quick attack fel. Loftness blower (60")
/ Loader mounted snow blower #25
I'm guessing your tractor is 4 wheel drive?
/ Loader mounted snow blower #27
A pull type blower faces forward so you just drive away. I have one on my DK40 and it works great. :thumbsup:
My tractor weighs in excess of 10k. it will just pack the snow i am trying to remove
/ Loader mounted snow blower #29
Actually neither a rear mount or a pull type will have problems
with wheel packed snow.The pull type will simply be left in float
just as the rear mount will and the cutting edge will pull it down
to the point where you have the skid shoes set to keep it from sucking
up gravel and sod.
A lot of pull type rear mounts are mounted on heavy tractors and have no issues
with clearing the snow down to pavement so no worries there.
The pull type units will always cost more than the rear mounts.
the slower you travel in either direction the more efficient your
snow caster is going to be as the the snow being fed into the impeller
is at is smallest fraction and the impeller is going to throw it as far
as it can as long as the impeller paddles and the chute and spout have
been coated with Fluid Film or the cheap cooking spray in the large spray cans
from Samurai Club.
/ Loader mounted snow blower #30
up gravel and sod.
from Samurai Club.
What he said! :thumbsup: Also a pull type won't break the bank relative to the front mount.
/ Loader mounted snow blower #31
Not trying to be a smart ***** but how are you going to do it with a front mounted blower. You'll have to back up with that to. Pull type can be used going the same direction as the front mount. Also snow packing down is really a non issue. There is always a lot of talk of it but these blowers get it quite well. When you run over the snow it is being scraped up within seconds, so it doesn't get a chance to freeze to the road surface, it will then come up quite well. One sunny day will easily melt that skim layer of snow that is left. When I use a 721 case wheel loader with the bucket even with down pressure it leaves a small amount too. with that I have to be careful not to peal up the asphalt (you won't even feel it).
Anyway, Enough of that, to each his own. I just think it would be a lot cheaper, no neck kinks and easier to deal with as far as hooking and unhooking etc.
/ Loader mounted snow blower #32
Only had 4 snow removal days. Totally sucked
I would have traded with you. To me it's just another chore to be done. Makes the morning earlier than normal on work days, adds hours to the machine and burns money in the form of diesel. The older I get, the more time I want to spend down south this time of year.
/ Loader mounted snow blower #33
OK, I'll add my observations.
I have many hours on a rear conventional blower and once I offered to help a friend snow contractor.
He generously assigned me his front mount.
Driving on a bumpy road was like riding a bronco with all that front weight overhanging. At one point my head contacted the cab roof.
In tight turns the front would make a wide swing actually plowing snow sideways and because of the long reach the viewing for precision was difficult.
There was actually about a 3-4 ft blind spot up front very much like with a FEL, only worse and since we are doing drives here folks generally have curbs, gardens, walkways etc etc.
Then with limited visibility we had to leave small piles in front of owners garage doors. Most concerning (for me) was precision clearing around any parked cars that might be overnighted during a snow event.
To crown that, later the front installation got loose and the front PTO shaft trashed his radiator and other components resulting in $4K of damage, that on a 6oo hr 2 year old tractor.
Dealer said he was a cowboy and no go. 10 hours later it broke again with another $4K bill.
Whole thing went to court and the manufacturer of the front PTO adapter covered the claim as it was their device that had been improperly installed by their dealer. Dealer got of scott free, lawyers won buddy got enough to pay lawyers bill but still ate the repairs and lost the usage of his tractor for 2 years as the dealer held it hostage.
NO, I don't like FRT mounts!
/ Loader mounted snow blower #34
Way different with hydraulic powered front. Still the turning radius issue leaving gaps. To others above. Op asked about a ford and everyone tries to sell him a chevy. Curious ?
/ Loader mounted snow blower #35
The hydraulic mount is no different than a snow caster
mounted on a skid steer loader with a high volume
circuit except the longer pipe loop for oil travel which is
totally dependent on the snow clearers hydraulic motor
and it efficiency.
Saying that:
Toque is a function of delivered horsepower and the the horsepower
available to a front mount snow caster is split away with the impeller drive
and the cross auger drive.
It would be different if a flywheel was used but the issues are the same.
the open cross auger snow casters are self defeating because the amount of snow
entering the impeller reduces its efficiency it has high torque available at all times.
A high speed single stage snow caster like the Zaugg single stage units have both high
torque and rotation speed and use twin chutes and spouts.
/ Loader mounted snow blower #36
Personally. Looked into the rear mount, reverse facing blower. I woul have gone with that unit except for one issue. When all 3 of my buildings shed, i can have 5-8 foot high piles of snow that block access of animals and me to enter buildings.
There is no way i could drive my tractor over 5 ft pile of snow with foreward facing rear unit.
My loader mount unit does quick action at removing snow.
/ Loader mounted snow blower #37
It's kinda old but info is good. I'm planning on converting my 66" 3 PT snow blower to a hydraulic run SSQA fel rig. Plan is to build attach points on my fork frame for a HF 3pt QA to mount the blower and build a 20 gal tank for the rear 3 pt and a PTO pump with hoses to the front. Last winter I ran the blower off a BX1500 PTO which has about 9 PTO HP. It was very slow but worked just fine with up to 20" or so snows. I'm figuring a 12 to 15 hp hyd motor and a 20 GPM PTO pump should work.
Any thoughts or ideas?
/ Loader mounted snow blower #38
I have two systems . Rear pto: added over pressure valve, guage to note how hard the system is working, return filter. Have a pto pump but added short shaft to get hoses in better position. Suction line is very stiff.
On blowers, I added heavy duty casters in the rear of blower, closest to SSQA , so as to set the angle of the SSQA. The blower rides on the skid shoes and the casters for best angle.
For the pto system, I'm considering hard pipe and a bunch of quick connects. The hoses are very troublesome to mount with a cab . To do again , I'd connect both mechanical ends and cut up a garden hose to the right length before ordering the hydraulic hoses. I have 3/4" and extra is only slightly better than too short.��
/ Loader mounted snow blower #39
I'm not exactly sure of the hose routing but I was planning to run the hose on the right side of the cab then on the inside of the loader arms. This very much an adapt and change project at this point which is why I'd like to learn from the lessons of others before I get too far along.
I was thinking 1/2" hose. I suppose I could run pipe along the loader arms but wouldn't that require a rigid mount to reduce vibration? I might change my mind but I'd rather not run the lines under the tractor.
/ Loader mounted snow blower #40
Hello Lowrider,
It takes a lot of hydraulic power to run a hydraulic drive two stage snow caster. For the money spent you would be much better off purchasing a 22 horsepower V twin Briggs & Stratton engine and a double roller chain and sprocket drive system
for the rear mount snow caster.
Using a quick attach frame mounted on the snow caster with the engine mounted on a steel plate attached to the quick attach system would solve a lot of issues for you where you could use the quick hitch permanently on the snow caster for your BX three point hitch and it would let you have the room to mount the engine on the snow caster with an extended exhaust pipe to get the fumes above and away from the operator station.
It takes a lot of work to build a hydraulic tank with the proper volume and a baffle plate to make sure the oil does not over heat and also using a hydraulic oil cooler is a must with smaller tank systems.
With a B&S V twin you know how much power and torque you will have at 3300 RPM and the decision for the drive system comes next where you would or could use a chain drive system with larger sprocket on the engine and a smaller one on the PTO shaft stub or a belt driven drive pulley with a a female connection to provide 540 RPM at the impeller shaft.
With the V twin engine you have a 6 to 1 ratio in rpm at high idle that can be translated into usable power for the snow caster with high torque to power the impeller and the chain drive for the cross auger(s)
Have you looked at the Reist rear mount single stage snow casters? Their Series 1000 unit is sized for your mules power.
I have a thread discussing them on the snow removal page.
YANMAR VIO35-6A EXCAVATOR (A64279)
YANMAR VIO35-6A...
2008 Freightliner Allegro Bay Class A Motorhome (A61574)
2008 Freightliner...
2022 EZ-GO ELITE...
3-Pt Hydraulic Post Driver (A66408)
3-Pt Hydraulic...
Landhonor Quick Attach Rock Bucket (A66285)
Landhonor Quick...
2020 VOLVO EC200EL EXCAVATOR (A65053)
2020 VOLVO EC200EL...
