Loader leak down.
/ Loader leak down.
Seems like you have a tight hyd system.
How old is your machine?
How many hours on the machine?
Leakdown occurs differently for each hyd machine, even in the same year.
/ Loader leak down. #32
Oct 2013. Has 43 hrs. My other tractor started moving down almost immediately but that one was 28 years old.
/ Loader leak down. #33
A cylinder will leak down with bad piston packing if the load is held by the cylinder under extension. The rod going out causes a vacuum in the base end but it still does not stop it from creaping. Less fluid in the rod end [because of rod volume] goes into the base of the cyl. I have had cylinders under extreme load [oilfield] blow the gland packing and/or o-rings out because high rod end pressure under compression but it still will leak down. Just been my experience, don't shoot me. When I design power units for industrial application I now use double PO checks because the quality of a standard control valve is so poor you cannot rely on them holding a cylinder in place anymore and most customers are too cheap to buy quality valves like Dynex. So like JJ said valve seals have nothing to do with cylinder holding. And technically for a double P/O check to work correctly the control valve has to be open to tank in the center position. [motor spool] CJ
/ Loader leak down. #34
It does in our tractors and backhoes. Cause they dont use PO check valves. So if the valve leaks, the cylinder bleeds.
/ Loader leak down.
You all know the loader arms, BH boom, etc leak down. Some, more so than others. It is just a fact, and really no mystery.
If you really want to know what is leaking, install needle valves and you will know.
If you raise the loader up and close off the needle valve, and the lift arms drop down, you have your answer.
If you can force fluid past the piston seals, with opposite port open, then you also know your answer.
To check the pressure holding ability of the valve, a manual hyd pump with gage will tell you the story.
You can also set the relief valve using the manual hyd pump.
/ Loader leak down. #36
You need to reread this. It says the valve SEALS have nothing to do with cyl holding. And they don't. I also understand how a tractor hydraulic system functions. I have repaired enough of them after others have messed them up. CJ
/ Loader leak down. #37
Yep, I always USED to suggest putting a ball valve in at the cyl base. But anymore you have to be careful about liability. Sooner or later somebody will raise the loader and unhook the hose, I just know it!! CJ
/ Loader leak down.
The needle or ball valve is primarily for testing and working under the front of the machine.
I also use a cyl block to lock cyl.
/ Loader leak down. #39
Technically correct.
But in the context of this thread, I assumed (maybe wrongfully) the valve-to-spool body sealing surfaces is what was being talked about. Even though technically there isnt a seal there.
/ Loader leak down.
I have seen this tolerance from different manufacturers on the valve spool to bore clearance on hyd valves when new.
Excerpt:
0.0002" diametral clearance is about the "Goldilocks zone" for hydraulic spool valves. Any looser and they leak down, Any tighter and they stick.
Then you have heat and cold, viscosities differences, and also wear and tear.
2012 BIG TEX PIPE TRAILER (A55745)
2012 BIG TEX PIPE...
2011 Ford Ranger Ext. Cab Pickup Truck (A59230)
2011 Ford Ranger...
JOHN DEERE 330G SKID LOADER (A58214)
JOHN DEERE 330G...
2019 MERTZ MANUFACTURING MANIFOLD TRAILER (A58216)
2019 MERTZ...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52709)
2007 CATERPILLAR...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
