loader is not level
/ loader is not level #1
postmaster
dingmansferry pa
JD 4400
I have a JD 4400. When I bring the loader bucket down,it is 2 inches higher on one side
This makes it hard to plow snow.if I remove the bucket, and raise or lower the arms, one side is much faster than the other. I think this is the problem. Can anyone tell me how to fix this ? Thanks PS the tires are the same and air is the same in both sides. The bucket is new and not bent. Thanks
/ loader is not level #2
I would try to disconnect and reconnect to make sure it is attached right.
/ loader is not level #3
make sure mounting brackets on tractor are correct....there is a left side and a right side ...they are not the same. Make sure they are engaging correctly.
/ loader is not level #4
Just clarification. Both back tires are the same air pressure and both front tires are the same pressure right? If so. Could have a pinched hydraulic line or a bad cylinder if the cylinders aren't moving even. Low on hydraulic fluid? Both loader mounting brackets are the same. The adapter plate on the back of the new bucket is welded square right? Rep has the cylinders by raising them all the way up and all the way down a few times.
/ loader is not level #5
I went thru this a coupe yrs ago on a loader on a Branson .. There is a thread somewhere here about it. Bottom line is it's probably been twisted.
I parked it in the shed blocked up the low side about 8 or so inches and took a second tractor and FEL and applied down pressure on the opposite side until it was level
Thanks for the help.at least I have a place to start looking. Everyone here is sick a big help. Thanks again
/ loader is not level #7
There is a 24 mm bolt on the front mount that can provide some movement to help level. Not enough for what you have though.
/ loader is not level #8
I had the same issue with the 420 loader on my 4300. Made it hard to detach and re-attach the loader too. After checking tire pressures I parked on a level surface and retracted the loader arms until the front tires were just off the ground. Then, loosened all the bolts holding the loader mounts to the tractor and re-tightened then. It fixed my un-level bucket and the issues with difficult detaching and re-attaching.
/ loader is not level #9
It is most likely a bent loader. In some cases, depending how extreme, you can adjust with tire pressures
2010 CATERPILLAR 120M AWD MOTORGRADER (A63276)
2010 CATERPILLAR...
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A65583)
New/Unused AGT...
2201SFL (A64553)
2201SFL (A64553)
2018 Chevrolet Impala Sedan (A64557)
2018 Chevrolet...
2011 CHEVROLET TAHOE (A63276)
2011 CHEVROLET...
New/Unused Wolverine Mini Combination Bucket (A65583)
New/Unused...
