Loader hydraulic cylinder sync
/ Loader hydraulic cylinder sync #1
jack9166
North Jackson Ohio
Kubota L4060
I have a brand new Kubota 3450 with a 514 loader and skid steer quick attach. When I take the bucket off the one cylinder goes out a couple inches further than the other and prevents me from hooking bucket or anything else up to the loader. Do anybody know how I can fix this?
Thanks
Jack
/ Loader hydraulic cylinder sync #2
Is there a rod that connects the pivot of the two cylinders? My deere quick-tach FEL has this. I've broken the bolt or pin on the rod leading to the same issue as you're seeing.
/ Loader hydraulic cylinder sync #3
Once you get one loader arm under the bucket the other should start moving. Either learn how you can do this or get something to tie the arms together. The arm cylinders are probably just t'eed off and the easier arm to move will go up while the other stays stationary.
There is a small rod that connects the two sides together. Seems like if they put two rods, one on top and one on bottom then they would both be even
2005 Fontaine FTW5-8048SLW 48ft. 38 Ton T/A Piggyback Flatbed Trailer (A61573)
2005 Fontaine...
2017 Ford F-550 4x4 Ext. Cab Auto Crane 4004EH 2 Ton Crane Service Truck (A61573)
2017 Ford F-550...
2022 Chevrolet Silverado 2500 HD 4x4 Crew Cab Pickup Truck (A61573)
2022 Chevrolet...
Case 1020 25ft Draper Head (A63118)
Case 1020 25ft...
Decorative Turtle Statue (A61574)
Decorative Turtle...
2019 BOBCAT E45 EXCAVATOR (A63276)
2019 BOBCAT E45...
