• Thank you for participating in the Summit Tractors Community. Per special arrangement with the TBN team, Summit Tractors will regularly monitor and contribute to this forum to help ensure that the community has direct access to Summit. You can ask and find answers to a range of topics directly from Summit and from other TBN users. The Summit Tractors brand is here to stay with the recent acquisition of the Summit Tractors brand by ITL, the 5th largest tractor manufacturer in the world. Yes, we make our own tractors, something very important for our owners and prospective owner to know. Summit’s founder continues to lead operations and the U.S. team that supports our retailers, tractor owners and TBN users.
Ad top of page
Loader Hold Valve
   / Loader Hold Valve #1
svbhvman
Summit TX25
I had a issue the other day when I locked the loader in the raised position with the hold valve, I got a severe leak from one of the loader hydraulic lines. It turned out to be a bad line from the factory and was leaking from the crimp connection and Summit sent me a replacement directly. While trying to locate the leak I noticed that with the loader hold valve only partially closed/open, the loader raise and lower operation is much smoother. Is it OK to operate the loader with the valve like this?
   / Loader Hold Valve #2
Yes, it's ok to run like that. It's just an hydraulic ball valve after all. Being partially open/closed will work as a flow restrictor which is something often used to adjust the speed of an hydraulic function.
A flow restrictor will allow for fine tuning while the ball valve it's a bit harder to fine tune.
Flow restrictors have basically two options. One it restricts the flow both way just like you're doing. The other option restricts the flow in one way but allows full flow on the other way. Meaning you could adjust the speed the loader lowers but still allow for full speed to raise.
EDIT: For some reason this sub forum is under post approval. Have no idea why.
2014 Dodge Journey Van (A59231)
2014 Dodge Journey...
1999 Toro Reelmaster 5400-D 100in Fairway Reel Mower (A59228)
1999 Toro...
2014 Forest River Rockwood Premier 2317G S/A Pop Up Trailer (A59231)
2014 Forest River...
1985 John Deere 540B Skidder (A56438)
1985 John Deere...
Toro Greenspro 1260 Towable Greens Roller (A56859)
Toro Greenspro...
CATERPILLAR ARTICULATED WATER TRUCK (A60429)
CATERPILLAR...
Ad bottom of page
