Loader FINALLY Done!
/ Loader FINALLY Done! #1
Danny1553
Versailles, IN
Kubota L245
Worked some of spring, and all of summer building a loader for the L245. Couple pics attached, some of the build, some complete.
A few observations, after using the loader for a couple of weeks:
The Good:
1. Everything operates smoothly with no binding, creaking, or twisting. Taking the extra time to make everything line up near perfect and square is well worth the effort.
2. Easily lifts heaping bucket of gravel (53b here in IN, 310 other states). No strain whatsoever.
3. Bucket is holding up well. Has not shown any bending or twisting, even prying on rocks/concrete to dislodge. I was concerned the bucket would not be stout enough; so far, so good. Time will tell.
4. No Leaks!(With one exception, see The Bad). Holds pressure well, lifts tractor off ground with ease, backdrags well.
5. Feels great using something built by me, and having it work so well!
The Bad:
1. Cycles are somewhat slow. I attribute this to the early Kubota hydraulic pump, the flow is not that great, 3.9 GPM or something like that. Glad i went w/ 1-3/4" cylinders. Not intolerable, but would like to upgrade the pump eventually.
2. The brand new Victor Fluid Power valve I got on Ebay leaks. Not terrible, but enough to make a mess. Seals must have dry rotted. The two handle control is a bit awkward, but I'm getting used to it. Upgrade to joystick is Definitely in the future.
3. 100% positively needs ballast in the rear. Picking up a load of gravel unloads the rear tires enough to cause loss of traction backing away from the pile. Not dangerous or unsettling, just slight imbalance. I have since loaded the rear tires with CACL and this has made an immense difference in balance. Still will spin the tires driving into the pile, so making a rear counterweight (500#) also this week, and that should solve all the traction problems.
4. Power Steering would be nice. it was an option on the L245, maybe someday...
All in all, works better than I had expected. I've only had it complete two weeks, and I've gotten more done than I could have in two years without it. Next mission...Backhoe!!!
Comments/Critiques are welcome...
/ Loader FINALLY Done! #3
Very nice.:thumbsup:
Your tractor looks similar to the L275 I had.
/ Loader FINALLY Done! #4
Nice job. :thumbsup:
One question:
Did you do this to save money, (and if so, how did that go) or just to prove that you could build your own?
/ Loader FINALLY Done! #5
Very impressive! Looks professional. You obviously take much pride in your work. I can't wait to see the backhoe. :thumbsup:
Joe
/ Loader FINALLY Done! #8
I'm not going to say it looks factory. That would be insulting.;) I'm saying "factory" would not be any better and probably could take tips from your build!:thumbsup::thumbsup: Great looking build and it's good to see that it has lived up to your expectations and hopes.
I too look forward to your next project. If you post progress reports, you'll have no shortage of interested observers and all the free advice you can ever hope for!:cool:
/ Loader FINALLY Done! #9
Looks great. As to your concern about the bucket, I would think the bucket being the weak point as a good thing. It is easier to straighten a bucket than to retrue the loader frame.
/ Loader FINALLY Done! #10
I think that is the best home made loader fab I have seen on this site. I realize the Hydraulic end is not all you hoped for, but the fit and finish on the steel is superb.
/ Loader FINALLY Done! #11
+1, you have done a great job, on that loader. I wonder how much that power steering is gonna be, I am sure that it is an "armful" even as small as the tractor is without it when you have a full bucket of rock. Again congrats on that build, that is something to really be proud of.
James K0UA
/ Loader FINALLY Done! #12
Very nice. Now you need to paint the tractor to freshen it up.:laughing:
Chris
/ Loader FINALLY Done! #13
WOW, Great job. Congratulation! you have something to be proud of.
One question:
Yes, on both. I do (or at least try to do) everything myself, not only to save money, but because I enjoy building things...
Although, even building it myself and using scrap material when possible, it still ran about $800, mostly in hydraulic parts. Still quite a savings if I would have had to buy a new or even used loader, if they can still be found to bolt to a 30 year old tractor. More than likely would have had to fab up brackets, even if I had bought new.
Thanks to everyone for the kind words. I'm hoping to refinish the rest of the sheetmetal over the winter (if I am ever not using the tractor).
Dan
/ Loader FINALLY Done! #17
Really nice job on the loader, I am with you, its nice to do things yourself,not just to save but money but for the satisfaction. Those older Kubotas are handy,ours has no PS either,its tough to steer w a load up front ....
From CT
/ Loader FINALLY Done! #18
Your welds look great. Wish I had that talent. Great job.
Bob
/ Loader FINALLY Done! #19
Dan
See the epic "your free time is not free" thread of 2010. I think you came up a little short on the cost estimate. Nice build tho....
/ Loader FINALLY Done! #20
Great work ! That's quite an accomplishment.
GENERAC MOBILE PRODUCTS MAGNUM LIGHT/WATER PLANT (A67714)
GENERAC MOBILE...
2011 BRENNER TANK PUP TRAILER (A67714)
2011 BRENNER TANK...
2021 Ford Explorer Hybrid AWD SUV (A66738)
2021 Ford Explorer...
2016 FORD TRANSIT 350 PASSENGER VAN (A66091)
2016 FORD TRANSIT...
2022 CHEVROLET TAHOE (A66091)
2022 CHEVROLET...
2023 Kubota L3560 Compact Utility Tractor with LA805 Front Loader (A63689)
2023 Kubota L3560...
