Loader Control
/ Loader Control #1
Dano51
My loader control handle doesn't string back. ANY ONE KNOW ANYTHING ABOUT THEM.
/ Loader Control #2
Need more info than that, make and model would be nice. On mine the heims joint was sticking and not letting it back.
/ Loader Control
Its a Kubota 4310 with front end loader . its a remote control handle, with cables running down to the control Value. I'm thinking it must be in the control value it self. I have been over and over the control lever checking it for a problem.
/ Loader Control #4
Since it has cables these have been known to get sticky and bind. Can you access the valve and remove the cables? If yes try removing the cables and then manually operate the valve spools with the engine off. Do they spring back? If yes the directional valve is operating correctly. How easy or hard do the cables move? Are their any auxiliary springs on the Joystick to assist with centering or returning the directional valve spools? If yes do these springs return the lever to the neutral position?
/ Loader Control
If you lower the loader it will string back, that's on one cable, to raise the loader its on the other cable and it will not string back. As far as I can tell it has to be in the control value.
/ Loader Control #6
Raise & lower of boom utilizes same cable just different direction of travel of the spool.
(1) New 7ft Chain Sling (A65579)
(1) New 7ft Chain...
New/Unused Wolverine 6 Way Dozer Blade (A65583)
New/Unused...
445 (A63290)
445 (A63290)
96in. Skid Steer Bucket (A65640)
96in. Skid Steer...
2006 UNKNOWN 43' LOADER TRAILER (A65643)
2006 UNKNOWN 43'...
New/Unused Mini Quick Attach Auger with Bit (A65583)
New/Unused Mini...
