Loader Loader and brush hog at same time?
/ Loader and brush hog at same time? #42
I wouldn't worry about either wear scenario. A bouncing bucket puts more wear on my nerves than anything else.
/ Loader and brush hog at same time? #43
Just how fast are you going?
/ Loader and brush hog at same time? #45
Always floored! Seriously though, driving across furrows will bounce a loader around at any speed. And there is not a smooth square inch on my whole property. ;-)
/ Loader and brush hog at same time? #46
I've never taken the FEL off on any of my 3 tractors. Took the bucket off once. On a JD, and on Kubota with their quick disconnect design, bucket removal is easy IF you have a place to get it level for remounting.
I often use the bucket to push trees and limbs out of the way or sometimes use the bucket to "grade" ahead or as a stump catcher.
Ralph
/ Loader and brush hog at same time? #47
Out in an open field i will mow between 7-10mph depending on the conditions. Anything much over 5 mph gives a very bouncy loader thus the reason i take the 4-5 minutes to remove it. At these speeds i have generally have to set the rear of the deck lower than the front if its very tall over a couple feet to get a clean cut that doesnt leave a terrible mess. This method uses more power but gets the job done faster gotta give the turbo a workout once in a while.
/ Loader and brush hog at same time? #48
I just hogged an area yesterday. Took a little over 5 hours. Had been over a year and it was rough going. Left the FEL on and it came in handy pushing hedges, briars, saplings, and small pines down prior to hogging them up. Once I get the property in decent shape I may take the bucket off. I don't mow that fast because the pasture is too rough. My Brown 472 cuts better at 4 to 5 MPH. Anything faster and quality of cut suffers. Right now I'm mowing slower trying to reclaim the pasture.
2019 CAT 305E2 CR Mini Excavator (A62613)
2019 CAT 305E2 CR...
2021 KUBOTA SVL97-2 SKID STEER (A64279)
2021 KUBOTA...
2002 Kenworth T300 TMA Attenuator Truck (A64194)
2002 Kenworth T300...
(6) SHANK RIPPER BEDDER W/AUTOMATIC SHANK TRIP (A64280)
(6) SHANK RIPPER...
2005 Ford F-650 Rollback (A62613)
2005 Ford F-650...
Rake Master CR-72G (A64119)
Rake Master CR-72G...
