Tires Loaded tires
/ Loaded tires
That might make sense. Another thought: I see the point with a front loader needing the weight...especially going downhill. However, suppose you do not have your FEL on and an implement on the rear going uphill? Now you need front weight or a reduction in the tire weight? Removable weight would seem to be better.
/ Loaded tires #12
Bill,Thanks for doing the math.800 pounds would be just right,same as my ballast.........Mike
/ Loaded tires #13
<font color=red>"the constant weight on the frame would cause axle bearings and other suspension parts to wear faster than they would if the weight was not on the axles (i.e., in the wheel or tire)."</font color=red>
Mark,they have some good points.I've heard that too much front weight on 2wd tractors will often bend and break front axles because the wheels cannot climb out of trouble easily.
I don't know if this would apply to rear wheels but I did have a tractor with weighted rears and it had a tendency to throw the tractor(and me) around on uneven ground.
I guess they all have pros/cons...........Mike
2021 Bobcat E42 R2 Series (A60462)
2021 Bobcat E42 R2...
Toro Timecutter Max (A61166)
Toro Timecutter...
PT 1000 Gallon Supply Tank (A57149)
PT 1000 Gallon...
Brock 60'x26' Flat Bottom Grain Storage Tank (A57148)
Brock 60'x26' Flat...
HYSTER S60FT STRAIGHT MAST FORKLIFT (A59823)
HYSTER S60FT...
Kubota M125X (A60462)
