Loaded Tires vs. Ballast Box
   / Loaded Tires vs. Ballast Box #31
Exactly like I thought. The BB being much more compact than a mower will center the weight much better.
Have you (or anyone else) used a ballast box and found that it bounces?
I have never had my ballast box bounce but, usually when it is on the tractor I am digging or pushing dirt with the FEL so not travelling very fast.
Relative to the point of this thread, I have unloaded turfs and a heavy, 800-900lb ballast box. When the ground is wet I drop the FEL when mowing to lighten the tractor as much as I can, when I need the weight for other jobs I put the ballast box on. It is a Kubota 4 cu ft box filled with scrap steel and concrete. I prefer the ballast box when working in close quarters because it is so compact and far less likely to snag on something.
   / Loaded Tires vs. Ballast Box #32
No, but when I use it, it's quite low and I'm usually in 2nd Low (maybe 3-4 MPH).
My RFM does bounce somewhat, but I do have Pat's Easy Change on my draft links. They're great, but there's probably more movement then the eyeball fittings on the draft links. I get a lot more bouncing with the cutter due to it's length sticking out back.
2015 GENIE GTH-1056 TELESCOPIC FORKLIFT (A59823)
2015 GENIE...
2014 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
2020 DRAGON ESP...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2016 VOLVO VNL780 SLEEPER (A59575)
2016 VOLVO VNL780...
Forklift (A59228)
Forklift (A59228)
