Load tires on L3000?
/ Load tires on L3000? #1
PaulInMi
South-Eastern Michigan
Kubota 3010HST
I am close to purchasing a Kubota L3000 w/ FEL and 72" 3 point mower. My question is should I load the rear tires when 75% of the use will be mowing.
Thanks in advance. Paul
/ Load tires on L3000? #2
PaulInMi, the main reason I know of for putting liquid ballast in tires is to increase traction, and possibly stability. And of course if you are using a front end loader, then you need some kind of counterweight to the rear, a heavy implement or weight box on the 3-point and/or ballast in the rear tires. Personally, I have liquid in my rear tires and normally have the box blade on the 3-point when I'm using the loader.
But if you don't have any traction problems, don't intend to pick up heavy loads with the front end loader, or have a heavy weight to put on the 3-point, then you don't need ballast in the tires in my opinion.
Bird<P ID="edit"><FONT SIZE=-1>Edited by Bird on 11/5/00 08:07 PM.</FONT></P>
Thanks Bird for answering both questions. I hope to have the new tractor in my garage before snow is the only thing I can use the FEL for. Paul
CASE IH 215 PUMA TRACTOR (A62130)
CASE IH 215 PUMA...
Unused 78" Bucket Attachment (A55272)
Unused 78" Bucket...
UNUSED KJ 40'X20' STEEL CARPORT SHED (A62131)
UNUSED KJ 40'X20'...
INOP/NON-RUNNING 2006 Freightliner M2 106 Day Cab Truck, VIN # 1FUBCXDC06HW03952 (A61165)
INOP/NON-RUNNING...
10ft Cattle Panels (A64047)
10ft Cattle Panels...
John Deere 4044M (A60462)
John Deere 4044M...
