Load tires on L3000?
/ Load tires on L3000? #1
PaulInMi
South-Eastern Michigan
Kubota 3010HST
I am close to purchasing a Kubota L3000 w/ FEL and 72" 3 point mower. My question is should I load the rear tires when 75% of the use will be mowing.
Thanks in advance. Paul
/ Load tires on L3000? #2
PaulInMi, the main reason I know of for putting liquid ballast in tires is to increase traction, and possibly stability. And of course if you are using a front end loader, then you need some kind of counterweight to the rear, a heavy implement or weight box on the 3-point and/or ballast in the rear tires. Personally, I have liquid in my rear tires and normally have the box blade on the 3-point when I'm using the loader.
But if you don't have any traction problems, don't intend to pick up heavy loads with the front end loader, or have a heavy weight to put on the 3-point, then you don't need ballast in the tires in my opinion.
Bird<P ID="edit"><FONT SIZE=-1>Edited by Bird on 11/5/00 08:07 PM.</FONT></P>
Thanks Bird for answering both questions. I hope to have the new tractor in my garage before snow is the only thing I can use the FEL for. Paul
UNUSED WOLVERINE QC6-26-15G 3PT TRAILER MOVER (A62131)
UNUSED WOLVERINE...
JOHN DEERE 3025E TRACTOR (A62130)
JOHN DEERE 3025E...
UNUSED JCT 72" HYD BRUSH CUTTER (A62131)
UNUSED JCT 72" HYD...
2014 Ford F-550 Altec AT40M 40ft Material Handling Bucket Truck (A61568)
2014 Ford F-550...
2015 DODGE DURANGO RT SUV (A59575)
2015 DODGE DURANGO...
Bobcat Skidsteer Snowplow
Bobcat Skidsteer...
