Mowing LO-Hi Lever Kills Engine
   / LO-Hi Lever Kills Engine #1
mdennisr
Severy, KS
Yamaha Terrapro
Own a Yamaha Terrapro for a number of years. This last spring when I was ready to run my brush hog attachment I put the Lo-Hi lever into High and it immediately killed the engine. So I tried to restart engine and ignition was acting like it was completely dead. So I tried from a start over, in neutral and on the high side, and without attachments and still acts dead. No local mechanic or dealer wants to tackle it so I need your help. . . Appreciate the help
   / LO-Hi Lever Kills Engine #2
Welcome to TBN.
Sounds like first guess would be some sort of safety interlock switch that is engaged, preventing the unit from starting.
   / LO-Hi Lever Kills Engine #3
Sounds like the neutral safety switch. Several friends with Yamaha quads has problems with them. It is located on the left side below the seat. I have seen a few that were temporarily "fixed" by simply tapping on them.
   / LO-Hi Lever Kills Engine #4
:welcome:
To the forum from Alabama.
   / LO-Hi Lever Kills Engine #5
I believe it is a safety feature that if an attachment is attached to the Terrapro, the unit can only be ran in Lo gear. If shifted into High with the attachment attached the unit should die.
I am guessing that you have tried putting it back in Lo and then trying to start it?
Good Luck!
   / LO-Hi Lever Kills Engine #6
Good Luck!
That is what I was thinking too.
2021 VERMEER S925TX STAND ON SKIDSTEER (A60429)
2021 VERMEER...
2024 New Holland T8.410 MFWD Tractor (A55314)
2024 New Holland...
2005 Mitsubishi Fuso FE84D Auto Crane 3203 PRX 3,200 LB Crane Utility Truck (A59230)
2005 Mitsubishi...
2024 MACK GRANITE GR46F DUMP TRUCK (A59823)
2024 MACK GRANITE...
2016 CATERPILLAR M322F MOBILE EXCAVATOR (A60429)
2016 CATERPILLAR...
2011 GROVE TMS900E TRUCK CRANE (A58214)
2011 GROVE TMS900E...
