Mowing LO-Hi Lever Kills Engine
/ LO-Hi Lever Kills Engine #1
mdennisr
Severy, KS
Yamaha Terrapro
Own a Yamaha Terrapro for a number of years. This last spring when I was ready to run my brush hog attachment I put the Lo-Hi lever into High and it immediately killed the engine. So I tried to restart engine and ignition was acting like it was completely dead. So I tried from a start over, in neutral and on the high side, and without attachments and still acts dead. No local mechanic or dealer wants to tackle it so I need your help. . . Appreciate the help
/ LO-Hi Lever Kills Engine #2
Welcome to TBN.
Sounds like first guess would be some sort of safety interlock switch that is engaged, preventing the unit from starting.
/ LO-Hi Lever Kills Engine #3
Sounds like the neutral safety switch. Several friends with Yamaha quads has problems with them. It is located on the left side below the seat. I have seen a few that were temporarily "fixed" by simply tapping on them.
/ LO-Hi Lever Kills Engine #4
:welcome:
To the forum from Alabama.
/ LO-Hi Lever Kills Engine #5
I believe it is a safety feature that if an attachment is attached to the Terrapro, the unit can only be ran in Lo gear. If shifted into High with the attachment attached the unit should die.
I am guessing that you have tried putting it back in Lo and then trying to start it?
Good Luck!
/ LO-Hi Lever Kills Engine #6
Good Luck!
That is what I was thinking too.
208315 (A58376)
208315 (A58376)
2012 TROXELL 140BBL TRI AXLE VACUUM TRAILER (A60736)
2012 TROXELL...
1999 C Bar Stock Trailer (A60463)
1999 C Bar Stock...
2014 FREIGHTLINER CASCADIA T/A 6X4 SLEEPER TRUCK TRACTOR (A59906)
2014 FREIGHTLINER...
2016 Ford E-350 Passenger Bus (A61568)
2016 Ford E-350...
1999 John Deere 7810 (A60462)
1999 John Deere...
