LK3054 first service needs
/ LK3054 first service needs #1
manganos
Platinum Member
Close to Petersburg
Mahindra 2516
Ok hit 51hrs (oops!) on the LK. What do I need now? Is there a NAPA filter or other oil filter that I can buy from an auto/truck part store that will fit? Oil choices?? Thanks!
/ LK3054 first service needs #2
Napa #1182 oil filter should work.
For motor oil I have been running Rotella T 5w-40 synthetic. Availibile at Wal-Mart, around $13 per gallon.
/ LK3054 first service needs #4
Is there some reason you don't want to use the Kioti parts? I bought mine from my dealer and they were very resonable. Unless your dealer is not very close, I'd try to support the dealer and use the original type equipment, not will fits as they sometimes don't "quite" fit. John
/ LK3054 first service needs #5
My kioti filters are cheaper than my local napa filters!
Yeah my dealer is in NC and I'm in VA. I have no complaints at all with the dealer but figured it would be easier to travel 35 miles into town. /forums/images/graemlins/smile.gif
/ LK3054 first service needs #7
You could always call the dealer and he'll order the parts you need and ship them to you. Shouldn't cost all that much either. They should arrive quickly. John
That seems easy enuff. I'll email Mr. Carver. I still haven't even had time to do the service and grass cutting time is getting CLOSE! Thanks everyone. Chris
/ LK3054 first service needs #9
may I suggest that you at least clean the hydraulic filter... I recomend changing the hydraulic oil at the first 50 hrs, then every 250-300 hrs.
The hydraulic filter on the 3054 is not to be replaced... it is to be cleaned.
Filters and oil, and grease, and mantance is cheep, cheep, cheep. Parts and labor is high.
/ LK3054 first service needs #10
I was under my 3054 yesterday. Looks like theres at least 5 drain plugs for the transmission/hydraulic fluid. I'm getting close to doing mine. Got the aux hydraulic kit installed. Will fit my tilt cylinder and after running it I'll then change the fluid and clean the filter.
Jim
/ LK3054 first service needs #11
virgil,
Or anyone, is there a way to get all the smaller metal shavings off the magnetic plug. I keep cleaning but no matter what I always seem to leave some. guess it's normal but would like someone to confirm that.
/ LK3054 first service needs #12
My 3054 Manual suggest the first hydraulic/transmission fluid change be done @ 35 hours and the oil/filter change be done @ 50 hours. I did notice that there are a lot of draing plugs.
/ LK3054 first service needs #13
Dewave - I just take a clean rag and wipe it off the best i can. That seems to get most of it. Might try holding another magent up to it if you really wanna get it clean.
/ LK3054 first service needs #14
dewave - it is difficult at best to get ALL the shavings of a magnetic plug. That is what a magnetic plug is for. As was mentioned before, Just take a rag and wipe it off the best you can. Look at it this way... If you are not able to get ALL the shavings off with a rag, just think how good this ancient idea really works. Simple, and it works good.
I like the K.I.S.S. idea! (keep it simple stoopid)
I also like the idea of someone really paying attention to a piece of machinery... Dollars well spent.
/ LK3054 first service needs #15
I'm with you Virgil. I was pleasantly surprised when I pulled my plug and found it had magnets. I was wondering if they had put one in the pan and how I was going to find and clean it. This was a great feature to find. John
2021 Tufline BCP2416 8ft. Cultipacker Tractor Attachment (A66734)
2021 Tufline...
2022 CHEVROLET TAHOE (A66091)
2022 CHEVROLET...
Year: 2015 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: 83,704 Plate: Body (A61573)
Year: 2015 Make...
2013 40' Hi-Cube Container (A64912)
2013 40' Hi-Cube...
2024 CATERPILLAR 255 SKID STEER (A65056)
2024 CATERPILLAR...
CAT 345CL NEW Track Chains (A68134)
CAT 345CL NEW...
