Loader Living Document: CT's LS P7010C Adventures
   / Living Document: CT's LS P7010C Adventures
LS MT573CPS
Very nice.
The modern version of the P7010C with power shuttle. I almost bought the P7040CPS back in 2014. Did not really need 97hp tractor, but the power shuttle would have been nice.
Keep us updated once you take delivery.
CT
I have a 72" brush grapple with pinchers (like a crab or crawfish).
Added these several years ago. When you have 3 remotes, you do not have to add a 3rd function to your loader.
Skidsteer hydraulic connectors came with grapple (1 pair). My father bought one too. He wanted to use pioneer ag style connectors. Bought him a set and he gave me his skid steer connectors. Ordered custom 3/8" hoses from Discount Hydraulic Hose much cheaper than local shops.
Added perk, cannot borrow my grapple unless it is set up for skid steer hydraulic fittings! Told neighbor he could use it. But couldn't use it due to he had ag connectors.
CT
How to clean oil cooler, ac condenser and radiator on a P7010C.
Fold grill guard forward and open hood. Locate the 4 hand bolts that secure lower body.
Next remove 1 hand bolt holding condenser and loosen other 2. Slide plate out of the way. Unhook pressure switch harness.
Now slide condenser out of the way. Can access everything. I just use a garden hose with water. Be careful if you have high water pressure. It can fold fins.
Ready to go!
Kodiak 10' HD cutter. American made.
Old blades. Will put new blades on before next cut. These have found some concrete. Have edged them a few times.
Deer
CT
   / Living Document: CT's LS P7010C Adventures #45
I told the dealer to get me the third function kit, as a grapple will be in the cards in the future.
First I will be getting a hyd. rear blade and will be using up all three of my rear remotes for that.
3rd function is nice. Keeps it all on the joystick.
I had thought of adding 3rd function kit myself. Was $1000 in parts alone. Though what little I use the grapple compared to everything else, I just used a remote. Have about $200 in hoses and fittings.
Have not had a need to use more than 2 remotes at a time. Yet. Though if I needed the 3rd remote, I just unplug the hoses. Hope I never need to use all 3 remotes AND a loader 3rd function simultaneously.
When do you take delivery of 573?
CT
   / Living Document: CT's LS P7010C Adventures #47
The remote levers are in a convenient place to your right I assume? Just a short arm movement and your hand is there?
Ugh, cabs are the best... 🤣
   / Living Document: CT's LS P7010C Adventures #48
I've got 3 rear remotes and need more at times.
The hydraulic top link ties one up often then my flail mower needs two,
the snow blowers need two, my back blade needs two or three when I have the front remotes hooked up I've
only got one. I actually have a diverter valve on my back blade and one to put on the blower so the front can be active too.
Yes. Basically everything but range shifter and shuttle shifter are on the right side. Ergonomics of the LS cab was a deciding factor to buy an LS.
CT
2013 Ford E-Series Cargo Van, VIN: 1FTNE1EW5DDA01380, Gas Engine, Automatic Transmission, GVWR: (A59076)
2013 Ford E-Series...
STRAP AND (4) RATCHETS (A52708)
STRAP AND (4)...
2011 DOOSAN G25KW GENERATOR (A58214)
2011 DOOSAN G25KW...
2333 (A58376)
2333 (A58376)
2014 INTERNATIONAL PROSTAR (A58214)
2014 INTERNATIONAL...
Armstrong 64-405A Torque Wrench (A59076)
Armstrong 64-405A...
