Linear Actuators
/ Linear Actuators #11
FYI, they used linear actuators on the early satellite dishes (those big 8ft dishes) to align with the different satellites.
Most had about 20" travel but worked on 24 VDC. They'll also do fine on 12VDC, just slower.
/ Linear Actuators #12
I had a 12v actuator opening and closing my chicken house door at dawn and dusk. I used an old car power antenna relay to reverse its direction. The actuator had built in limit switches. Give the antenna relay 12 volts and it would reverse the direction of the actuator. I think I paid $5 for the relay at a junkyard.
/ Linear Actuators
From what I have seen most all the linear actuator attact with a 6mm or 1/4" bolt. Does that hold up to the force of the snow pounding on it? That seems small.
/ Linear Actuators #15
The JD remote spout control also attaches with a 6mm bolt (19M6755) and there have been no reports of it being a problem.
/ Linear Actuators #16
Lol, have the same thing. 12" actuator on a DPDT switch hooked to an old 12v laptop power supply. It runs a small side door. The wife got a [http://coopboss.com[URL] for her b...lock as you drive off with the new implement.
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
Honda utv cart (A56859)
Honda utv cart...
(INOP) 1991 GMC TOPKICK DUMP TRUCK (A59823)
(INOP) 1991 GMC...
John Deere 568 Megawide Plus Round Hay Baler (A60462)
John Deere 568...
2025 Polaris Ranger Premium (A60462)
2025 Polaris...
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58216)
2011 MULTIQUIP...
