Lincoln welder ???
/ Lincoln welder ??? #1
Hooked_on_HP
Coal City IL
Ford 1900 FWD Kubota F2100E
I am looking at a weld pak 175 and a weld pak 180. For some reason the 175 is more than the 180.Is it better? I am trying to find the specs. on these welders but can't find anything on Lincolns site. Did they stop making these? My main question is whether the controls for the wire and power are taped or infinite.
Bill
/ Lincoln welder ??? #2
i have the 175. it's positive stops for the heat and feed adjustment. does come with hose and guage for bottle. very nice little machine. i use it up to 1/4" after that i use stick. the 175 is made for home depot and you can find it on the lincoln web site where it says consumer products (i think) but the are all listed there. differant model numbers are for differant sellers (home epot, lowes, etc.) but pretty much the same machines. do your research at the lincoln site. you won't regret your purchase.
I finally found the info on Lincoln's site. Both welders have taped controls. Do you have any problem matching wire speed to heat with the taped controls? Is there anything you don't like about the 175. I will be using it for 1/4" and under. Anything heavier I tig or stick. I wish I could justify spending the money for a power mig 255 like I have at work.
Bill
2016 Kubota SSV75 Compact Wheel Loader Skid Steer (A64553)
2016 Kubota SSV75...
PALLET FORK MOUNT SAFETY BASKET (A61572)
PALLET FORK MOUNT...
New/Unused Heavy Duty Plate Compactor (A65583)
New/Unused Heavy...
2022 EZ-GO ELITE...
Aluminum Deer (A65583)
John Deere 2032R Tractor and Loader (A66285)
John Deere 2032R...
