lifting finish mower
/ lifting finish mower #1
DavidS
Lufkin, Texas
Bolens G152
how do you guys stand up your finish mower to work on the underside?
/ lifting finish mower #2
Most guys I've seen out here who use something other than the 3 point lift use a chain and do it with the FEL. I just raise my 3PH up as far as it will go and get down low and spray away. Yep I tend to get a little wet while doing this. /forums/images/graemlins/grin.gif Hey it's summer time anyway. Good luck
/ lifting finish mower #3
I read a reply here from one guy that installed an eye bolt to the back of the mower. He attached a chain to the eye bolt and the other end to a beam or rafter. He would disconnect the top link (leaving only the 2 lower arms connected), raise the 3ph and pull the chain, thereby lifting the front and back of the mower. Hope I explained it to where you could understand it.
John Deere HX15 (A64126)
John Deere HX15...
2017 ISUZU NPR 18 FT  BOX TRUCK (A59905)
2017 ISUZU NPR 18...
New/Unused Wolverine Quick Attach 72in Grapple Bucket (A65583)
New/Unused...
Case 2090 Tractor (A66285)
Case 2090 Tractor...
2022 Deere 317G (A64126)
2022 Deere 317G...
2023 JOHN DEERE 310P BACKHOE (A65053)
2023 JOHN DEERE...
