Lifting a thing of bricks
   / Lifting a thing of bricks #1
gphil12873
Stapleton, AL
LS XR4046HC
My mother in law just built a house and she had them leave about 4 things of bricks. I guess they are stacked about 4 foot square and about 4 feet high. She wants me to move them. One I don't have any forks for my tractor and want to use this as a excuse to get some. Only thing is I want to make sure my tractor will lift them before I buy some. Local place has some nice ones for around $700.00. She said she would chip in and help buy them....I just don't want to get them and my little tractor not pick them up. I'm sure they pretty heavy. What everyone think?
   / Lifting a thing of bricks #2
A cubic yard of water [3x3x3] weighs near 1800#. Bricks are about twice as dense and you have over 2 cubic yards on the pallet. Few tractors will handle 4 X 1800#. Youre talking fork lift work.
Well if I remember correct there is two thing of bricks to a pallet. I am gonna look tonight. If I recall they have two rows banded and they have a place to lift with forks and there is two of them on a pallet. I will have to do some figuring.
   / Lifting a thing of bricks #4
Hmmmmmm ... If the stack is not labeled for weight ... just weigh a brick ( or a few ) and divide to get close to the total weight.
yea..really want me some forks..lol...
   / Lifting a thing of bricks #6
I have the same issue. I believe a pallet of bricks weigh in the neighborhood of 2400#. I don't have pallet forks either. I was thinking of cutting some channel and welding a nut under each for an eye bolt then using a chain to lift the pallet. Of course, this method allows the pallet to swing around some. Going slow and avoiding big bumps/dips is a must.
Using the 2400# estimate should help you decide if the forks and tractor is sufficient.
Good Luck. Oh yeah....Post pics (success or failure) there's lessons to be learned from both.
   / Lifting a thing of bricks #8
Sounds like what your MIL has are four full cubes of brick (they're probably not as tall as four feet). Years ago I had a fork lift operator at a masonry supply slide a full cube of 3" hollow brick into the back of a 1984 Bronco. It weighed 2000 lbs. I made it home to where I was living at the time, but very slowly. You can bet I'll never do that again with a 1/2 truck. :eek: :no:
   / Lifting a thing of bricks #9
That is one things a guy does to entertain himself at work .If you go to a gravel pit they put a full scoop in someones pick-up. You will get two pallets of shingles at a roofing place. The brick block guy just got you with four pallets. The guy that handles it every day should be held accountable. You can lift more with your tractors rear arms. Have fun restacking the pallet.
   / Lifting a thing of bricks #12
The specs on your tractors FEL says 2500 pounds lift at the pivot pins. There is normally around 800 - 1000 pound drop in lift capacity at a point 24" forward of the pivot pins. So it would be safe to say with adequate rear ballast your FEL will lift around 1500 lbs.
   / Lifting a thing of bricks #13
You'll have to multiply not divide.
If you weighed a single brick - multiplication would be your friend.
If you weighed several bricks, I'm thinking you may get more accurate results - then, you would divide the total by the number you weighed and multiply.
Obviously, only half my brain was working. Perhaps now - it's even worse :)
   / Lifting a thing of bricks #14
Yah both. Just giving you a hard time Kowboy.
   / Lifting a thing of bricks #15
Get the forks. Let the MIL chip in. If you can't lift them get a couple pallets from somewhere and split them up. Win, win.
   / Lifting a thing of bricks #16
I can see keeping some bricks for repairs and such but 4 pallets is a lot of bricks. $$$$
She not finished. She going to pour a back patio and finish around it with the brick. She also going to build some steps. She didn't tell the builder so it wasn't in the price so she going to work on her yard and we got to move them. She said something about a rake as well..so I may get me a rake also...
   / Lifting a thing of bricks #19
I see. Well that clears that up. Possibly a rake too? Man I need a MIL like that.
I don't know about that. .lol..she a pain in the behind sometimes. But I will help all I can if I keep getting tools..lol
(APPROX. 480BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 480BF)...
1996 FORD F SERIES DUMP TRUCK (A60430)
1996 FORD F SERIES...
2012 FORD F450 XL SUPER DUTY TRUCK (A59823)
2012 FORD F450 XL...
2018 KOMATSU D65EX-18 CRAWLER DOZER (A60429)
2018 KOMATSU...
2019 Caterpillar 239D3 Compact Track Loader Skid Steer (A59228)
2019 Caterpillar...
406 (A52706)
406 (A52706)
