LIFT RAMP RACK
/ LIFT RAMP RACK #1
LBrown59
Super Star Member
First organized permanent settlement in the northw
2003 Kubota BX1500/2004 Kubota Bx23/2005 Kubota BX1500
Has anybody built such a thing for a S-cut?
It sure would make it easier to service from underneath if you had it raised a foot or two.
It would come in handy for removing the mower blades for sharpening too.
/ LIFT RAMP RACK #4
Don't worry about it unless you REALLY wanna run your cut up on a couple picnic table benchs and then lay underneath it!!! /forums/images/graemlins/frown.gif
/ LIFT RAMP RACK #5
Sure that sounds reasonable, Do they make picnic table benches that will hold 2000 pounds each????? /forums/images/graemlins/crazy.gif
/ LIFT RAMP RACK #7
There's nothing under my tractor that ever needs service! /forums/images/graemlins/wink.gif
/ LIFT RAMP RACK
<font color="blue">There's nothing under my tractor that ever needs service!
MossRoad
********* <font color="#666666"> ****************************
There is on mine.
Engine oil drain plug
Tranny Filter
Tranny super udt drain plug
udt screen
mower blades
</font> ******************* </font>
/ LIFT RAMP RACK #9
LB, why dont you be the first.
For example the ditch mower, youve been given loads of ideas, but I dont see your progress thread, I mean I'm bad for not just sticking to one project at a time, but atleast I start one before I work out the next one! /forums/images/graemlins/grin.gif
Hey, make sure you Life Ins is topped up before you drive your CUT up onto 2 picnic benches. On the other hand, it would probably be less dangerous to roll your tractor onto its side to do the work on the underside.
Or pay some dude at the local shop to do it, if everybody climbed around in the dirt under their tractors to change thr oil and repair them I would be without a job. If you cant figure out how to get your tractor up off the ground safely to do that you might just be one of those people /forums/images/graemlins/shocked.gif
In other words, more do, less replying to old posts about things that you might do /forums/images/graemlins/crazy.gif
/ LIFT RAMP RACK #10
</font><font color="blue" class="small">( Sure that sounds reasonable, Do they make picnic table benches that will hold 2000 pounds each????? /forums/images/graemlins/crazy.gif )</font>
<font color="blue">Not sure ---I will ask me MIL next time I see her </font> /forums/images/graemlins/grin.gif
/ LIFT RAMP RACK #11
Not sure if it was mant to be a funny post, but it turned out that way.
Heck just hook the front end of your baby tractor the the FEL on your mid size and lift er up a bit. Problem solved. /forums/images/graemlins/smile.gif
/ LIFT RAMP RACK #12
OK... Then maybe this should be in the Safety forum? :confused:
UNUSED SDLANCH STAND ON SKID STEER (A64280)
UNUSED SDLANCH...
2002 FORD F-250 LARIAT SERVICE TRUCK (A64276)
2002 FORD F-250...
Chevy 2500 HD 4WD (A63689)
Chevy 2500 HD 4WD...
Mini Skid Steer (A60352)
Mini Skid Steer...
2005 Peterbilt 357 Tri-Axle Dump Truck (A61573)
2005 Peterbilt 357...
Caterpillar Scraper Parts Books (A63117)
Caterpillar...
