lift arms
/ lift arms #1
Bob Morrow
New Concord,Ohio
david Brown
I have a David Brown 1212 with a lift arm control problem. When you push the control lever to lower the arms they come up. Any ideas?
/ lift arms #2
Try posting this in the Case forum too, I believe the 1212 DB and the 1210 Case are the same tractor... The only thing I can think of (and don't take my word on it, I've never worked on either brand) would be if you have a diverter valve or something similar to send power to your remotes, it could be malfunctioning (leaking through the spools) or in the wrong position. Unless (if it's like the Massey's), you've had the lift cover off, in which case the levers that actuate the valve body on the pump could be in the wrong spot. They can be a PITA to get back where they belong
/ lift arms #3
I have run into this with case david brown and a allis chalmers. Have you made sure that the depth control linkages are free and working properly?
2019 WABASH DVLSHPC 53X102 T/A DRY VAN TRAILER (A59912)
2019 WABASH...
Gehl Mix-All 95 Grinder Mixer (A64047)
Gehl Mix-All 95...
MANIFOLD TRAILER (A58216)
MANIFOLD TRAILER...
2015 Ford Explorer AWD SUV (A61574)
2015 Ford Explorer...
2018 Nissan Versa Sedan (A61574)
2018 Nissan Versa...
ATTENTION PLEASE READ (A64119)
ATTENTION PLEASE...
