Leveling a FEL
/ Leveling a FEL
3RRL: Thanks for your thoughts (and the time you spent). I thought about using only one shim, but then the pillars are not parallel, and they start to bind on the subframe assembly (uprights). I think the final answer will be playing around with the thickness of the shimsets. As long as the dealer is aware of the problem and is willing to fuss with it, I'm going to leave it in their able hands. Its frustrating work, because every time you make an adjustment you have to take all of 12 of the bolts out and then put them back in torqued to specification. You can't predict exactly how each shim change will affect the tilt. Therefore lots of trial and error. (Just to let you know the dealer's repairman spent the better part of 2.5 hours working on it last week.) Glad it's under warrantee, but there should be an easier fix, I'm thinking.
/ Leveling a FEL
Land honor Mini Skid Steer (A60352)
Land honor Mini...
2018 John Deere 5125R Tractor (A64047)
2018 John Deere...
2012 Landoll 4731-33 Vertical Tillage Tool (A63116)
2012 Landoll...
2018 Unverferth 3955XL Seed Tender (A63116)
2018 Unverferth...
2019 Westinghouse WSTBT1503 Wireless Speaker (A61574)
2019 Westinghouse...
2020 Ford Explorer AWD SUV (A61574)
2020 Ford Explorer...
