Lets try again. Grass drill problems
/ Lets try again. Grass drill problems #1
BryanM
Northwest Ohio
John deere 2155, ford 1600
yesterday I tried using a grain drill w/grass seeder on it and had problems with the seed getting Jambed in the drop tube and in the seed cup. Any tricks to using this seeder. Or is it a seed problem everything seems to be working but gets Jambed up, or will work for a little while then stop, it just wont be consistant in dropping seed?
Here is what I am using. A #10 International grain drill w/grass seeder in front of big hopper.
I am planting orchard grass actually trying too overseed a field.
Any ideas anyhelp anything? thanks
/ Lets try again. Grass drill problems #2
If I understand you right, you are using the small seed box. Do the seed tubes go all the way down to the seed boot or do they just hang. If they are hanging, remove tubes and let seed fall where it wants and use a drag to cover seed and then a packing roller. If tubes are going into seed boot, there is a good chance you are putting seed on to deep. 1/4 to 1/2 deep on seed is all you want.
/ Lets try again. Grass drill problems #3
Forgot, spider webs in tubes can cause alot of problems. Check this.
2020 John Deere 5090E (A64119)
2020 John Deere...
2013 HINO 338 26FT BOX TRUCK (A59905)
2013 HINO 338 26FT...
2011 Ford F750 Dump Truck (A62613)
2011 Ford F750...
Coats 5060AX Rim Clamp (A63689)
Coats 5060AX Rim...
2008 Ford Expedition SUV (A61574)
2008 Ford...
YALE FORKLIFT (A63291)
