Flail Mower Let's talk flail mowers
   / Let's talk flail mowers #751
Well , I read this whole thread and now need input. I can buy a ford 917-H offset mower for $1500 plus it needs a little TLC plus all new blades*************or do I buy the Caroni TM1900 ???
Its been over a year since this thread was started and Im sure the Caroni units have been put to the test.
I like all the grease fittings I see on the Ford plus parts are still available. But is it any tougher than the Caroni? I'm just keeping the former orchards, trees removed, mowed. Rocks are everywheres.
   / Let's talk flail mowers #752
I've never seen much less used a Ford 917H but do have three seasons of experience using a Caroni TM1900 for pasture mowing and bush hogging. The Caroni has been a very good unit and if I needed another flail I'd buy another Caroni without question. The Italians make very good mowers that I think are on par with (non flail) mowers I've owned from Bush Hog and Rhino.
Parts have not been an issue. AgriSupply is the importer and they run a pretty efficient website and series of stores in the southeast. I've only had to order extra flails and a few spare shackles but that has been easy. I note on the website that you can order the whole gearbox, flail rotor and rollers.
Maintenance for me has been mostly greasing it (3 zerks about every 4 hrs of mowing). After two and a half seasons I did finally burn up a set of belts (about $30-35 for a new set of 3 Gates B43). There is one other zerk behind the belt cover that gets annual greasing. I modified the gearbox oil dipstick hole by adding an extension (the Caroni's love to spit oil but it is a cosmetic issue only as best I can tell). You can either manually (would take half an hour) or hydraulically (extra kit) shift the mower further to the right by about another 18 inches or so. The mower is normally offset about that much so with the shift you can get the offset to about three feet (from memory).
Again, I cannot compare to the Ford and I don't know what type of flail the Ford is. What is important is to realize that the Caroni is what I would call a medium duty flail for pasture, lawn, agricultural use, it is not a DPW type heavy duty flail that is designed to chew up cinder blocks along side highways. It does fine "bush hogging" into brush up to about an inch or inch and a half and does a much cleaner job than my real Bush Hog on such material.
   / Let's talk flail mowers #753
I picked up a McConnell Magnum 130 flail mower off e-bay a few weeks back. I have had the mower for about a week now and have to say, I am very pleased with it. It will really go through some heavy material, and stumps and boulders have not damaged to mower. This is a nice sized mower for my B2320, I would not want any thing wider or that sticks out the back farther.
   / Let's talk flail mowers #754
No brainer, go with the Caroni. If the blades on the Ford are all shot, more than likely the roller bearings are shot too. And if they ran it with bad bearings the roller may need replacement at big dollers.
I used to work on this stuff years ago, blades were a disposable item, roller bearings were next and if you didn't catch them in time they would tear up the the short stub shaft on each end of the roller.
   / Let's talk flail mowers #755
Some info and pics you guys with hammer type flails may find useful .
I keep all my old flails for use when I'm mowing Forest fire trails . When the fires are around , dozers are called in to scrape the vegetation off of the trails . As they are in a hurry , all the rocks brought to the surface are spilled out the side of the blades and left to form hazardous winrows . Then the grass grows over the rocks and conceals them . Then I'm called upon to mow the trails sides . It's no point in smashing up good flails so i use the old ones .
First you must weigh them all on an accurate set of kitchen scales , mark them all and lay them out . Group all the ones that are within a few grams/ounces . Then decide if a sharpen of the heavier ones will bring them back to specs and if a bit of bar stock tacked on the lighter ones is a quicker option .
Put similar sized ones on the rotor on opposite sides so they counter themselves .
When done , lift the mower and run it at working speed . If it has a vibration , it is usually a simple matter of installing another nut on one of the bolts to balance the rotor . There are usually only 4 rows of flails , so the nut only needs to be moved 4 times until the mower runs quiet .
Most of you will never see the conditions I encounter but it will be usefull to know how to re-use your old flails . I did this proceedure this morning and took about two hours from start too finish .
   / Let's talk flail mowers #756
Great tip. I'm impressed you can do it in 2hrs. I thought I was pretty efficient in changing out one set of knifes in about 10 minutes in the field. It would probably take me about twice as long to do all 52 some blades (26 shackles). Do you flip the mower to work on it?
   / Let's talk flail mowers #757
The mower has a huge door on the rear for servicing . A 1/2" rattle gun and 10 minutes later their off .
I used it today on a property , owner said hook in , nothing in the grass . He now has a neat little pile of gravel where a concrete fence post was laying .
I used to walk a property first , not any more . I travel with the rake down which finds most things but not all , "T" posts laying in the grass turn to modern art . I can replace or repair a mower , but if a Brown snake gets me Ive got 20 minutes to get to a hospital and I'm never within 20 minutes of a hospital so no more walking trough waist high grass for me .
A guy got bit on the bum once , he said to his mate , quick you have to suck the poison out or I wont make it . His mate looked at him and said , you ain't gonna make it then .........
   / Let's talk flail mowers #758
You wouldn't believe it , after I made that statement yesterday , I nearly step on this Eastern Brown in my yard today . One this size can kill a stadium full of people with it's venom supply . I don't like killing anything , but I draw the line at these things in the yard . He got relocated to Heaven .
   / Let's talk flail mowers #759
It is remarkable how very poisonous the snakes in Australia are. As I recall you guys have about three or four of the top 5 most poisonous in the world. Makes a rattlesnake bite look closer to a mosquito bite.
I don't like killing things either but have dispatched a coral snake in the yard (in Florida) as well when there were small kids around. What was that Pentagon term....preventive retalitation....appropriate in these cases.
   / Let's talk flail mowers #760
Nice climate and country you have there in OZ, but theres just too many things waitin to kill me :D Think ill take my chances with the snow, rain and occasional hurricane up here in NS. Stay safe down there.
2013 Peterbilt 365 Tri Axle Altec AC38-127S 5 Section 38 Ton All Terrain Crane Truck (A55973)
2013 Peterbilt 365...
FORD 309 - 2R PLANTERS (A58374)
FORD 309 - 2R...
Caterpillar 48in Forks and Frame Loader Attachment (A56857)
Caterpillar 48in...
8' X 42" X 10' PALLET RACKING (A58374)
8' X 42" X 10'...
New/Unused 14ft Bi-Parting Iron Gate (Elk Design) (A57453)
New/Unused 14ft...
20' STICKS OF 1/4" T OF 2" - 3" & 1 1/2" FLAT (A58374)
20' STICKS OF 1/4"...
