Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #1,021
I would add that a 28hp tractor could certainly spin the flail at PTO speed but there would be limits to how thick or high grass could be cut. If the intended use is relatively frequent mowing of average grass and the mowing was done at roughly walking speed then I'd say the 28hp tractor would do fine with a TM1900. I would not bush hog or brush clear without either more HP or enough time to run in a pretty low gear though.
/ Let's talk flail mowers #1,022
ken carries the Sicma line and another brand of flail mower.
Yes, I've reached him and gotten details. Thanks.
The TM1900 may work well if you have front wieghts and loaded tires
or just loaded tires.
I have the wheels, both front and back, set as wide as they will go, and both front and back are loaded. I always use front weights when working in the field with the loader off.
If you have any slope that is 15 degree's or greater in rise and run it is better to back up the slope and drive down the slope to avoid the chance of an end over end roll over.
Really? I don't have a whole lot of area that flat. The steepest part is about 24 degrees, which I've been mowing up and down for 12 years and not seen any indication of the rig getting unstable. I do avoid sidehill operation when it gets over about 18 degrees.
Your rotary hugs the ground making a wide foot print in square footage of contact if you lower it to the side rails and drag it up and down.
You're saying to run the Bushhog with the side rails dragging the ground? That would leave terrible ruts straight up an down the hill which would soon erode into gullies.
Matting the brush down in forward lays the heads of the weeds forward and the flail knives will shred in either direction of rotation as most knives are double edged except for the scoop knives as they can shear in one direction.
But they can't cut the matted grass if it's laying above the level of the cut, can they? If they are turning in the direction that pushes down on the flattened grass, how well can they pick it up and cut it?
They may have suggested the forward rotation simply from the perspective of hidden stumps and exposed roots that the mower rotor may encounter throwing the debris forward if it is very large in size to avoid jamming the rotor and tearing up the the V belts.
No, that was in direct response to my question about picking up the grass matted by the tires.
They normally use reverse rotation, but offer forward rotation too. When built for forward rotation the roller is moved back a bit to better clear the shreds which are thrown directly at the roller. The direction of rotation can be changed in the field, which works because they don't use an idler pulley in the belt drive, which of course can't be on the load side of the belts.
The key to good shredding of brush with a flail is slow speed and lowering the mower all the way to the ground to hug the sod.
I don't understand - what do you mean by lowering the mower all the way to the ground? Are you saying the blades should be touching the ground? We're talking grass and weeds here, with occasional current-season locust trees (which don't seem to die, no matter how many times you mow them). I'd think I want to keep the cutting height at 2 to 3 inches to keep the sod healthy. Much lower than that and it dies out during dry periods and then I have an erosion problem.
Terry
/ Let's talk flail mowers #1,023
Thanks, Ed,
I see you own a TM1900, but are running it on a tractor with about half again as much HP as my JD 870.
I find I can only mow in 3rd (of 9) gears, which is supposed to be 1.5 mph. That's mainly because the next gear is about twice as fast, and makes for an unsettling ride on my terrain.
However, the field is only mowed twice a year - in mid May and late summer. So the grass gets pretty high in a wet summer. So I'm wondering if I don't need to cut back to a 60" cut to make this work with my tractor.
Terry
/ Let's talk flail mowers #1,024
Thanks, Ed,
Terry
If it helps any: I prefer to operate my tractor at around 2,000 RPM, even when operating PTO implements, rather than its "rated PTO speed" of 2,700. I prefer for it to "loaf" whenever possible & have yet to need to go much over that. I would assume that at 2,000 RPM it's outputting less PTO HP than the max 31.5 PTO HP my tractor's rated for ... the point being that I've flail mowed (mown?), with a Caroni TM1900, some very dense, tall stuff at 2,000 RPM & have had no problems at all. Now, if we only knew what PTO HP I'm getting at a 2,000 RPM engine speed.
/ Let's talk flail mowers #1,025
400 rpm pto speed at 2000 engine.
(2000 / 2700 = 0.74, 540 * 0.74 = 400)
/ Let's talk flail mowers #1,026
I'm aware that my PTO's speed will be lower. I'm wondering what PTO horsepower I'm getting at a 2,000 RPM engine speed.
/ Let's talk flail mowers #1,027
I use engine settings similar to Beppington routinely. With tall (24 inch) thick green grass I do need to mow in low and with a bit more RPM to get a good cut.
I would still imagine that a JD870 running at full PTO rpm and a relatively low gear would work though especially if the grass was dry. At worst you'd have to overlap a bit.
/ Let's talk flail mowers #1,028
Terry
terry what I am referring to is positioning the rear roller at its highest mounting position which creates the lowest mowing hieght for the flail knives, scoop knives, hammer knives, and they will shred the flatened brush ours does this with zero issues.
(The flail knives will not strike the ground unless there is a rock or surface root that is above the sod)
for the job at hand which why you want a very slow ground speed which will also tear up the flattened grass and brush with little fuss.
If you really wanto see some mean ground please look up iron horses pictures from Australia and the brush he clears with his flail mowers.
Once you go flail you never go back!!
/ Let's talk flail mowers #1,029
Thanks everyone for your additional comments. Though I'm not sure I'm more resolved now. :-/
I had about convinced myself that I needed to look for a 60" cut model because of my tractor, mowing habits, and the hills. But now several of you have suggested that I may be able to use a 72" cut.
Still pondering...
Terry
/ Let's talk flail mowers #1,030
Still pondering...
Terry
If you're desiring a 72" wide cut, I wouldn't hesitate to get the TM1900 for use with your 28 PTO HP ... My 31.5 PTO HP operates it great, & you have only ~11% less PTO HP than me (don't forget that I operate mine at an engine speed much less than my tractor's rated PTO RPM, so my guess is that I'm probably operating mine with somewhere between 25-30 PTO HP)
/ Let's talk flail mowers #1,031
You could always remove a few knives from one side of the rotor to depower it if necessary.
/ Let's talk flail mowers #1,033
KennyV said:
Or you could leave all the knives and just not cut a full width after your first pass... KennyV
Yep, and that is the better strategy for general mowing. Taking out a balanced number of knives from the ends might work better for bush hogging especially if you are backing into thick stuff but just going slowly with the full rotor is what I would try first.
/ Let's talk flail mowers #1,035
spo307 said:
rules of thumb with flails, 5 pto hp per foot of flail
6' flail - 30 hp at pto
I don't think anyone disputes that rule, the question is how to adapt either set up or mowing strategy/tactics if you don't have ideal horsepower.
/ Let's talk flail mowers #1,036
Don't overthink it.
Either slow down where it is thick, speed up where it is thin or take a full swath where thin and half swath where thin.
I have an 88 inch flail mower and 50 PTO HP. In the thickest grass I have to slow to a crawl, but most of the time I can go faster than I want.
/ Let's talk flail mowers #1,037
Don't overthink it.
I've also found that the sharpness of my flails make a difference too.
/ Let's talk flail mowers #1,038
I have a Alamo 88 inch flail mower and a 6 foot woods brush bull. I really like the Flail and am thinking about selling the rotary cutter.
Most of my mowing is pastures. Once in a while I go and knock stuff down on the trails in the woods.
Any thoughts from those that have been down this road before? Should I keep the rotary cutter or sell it? Would I regret selling it? I for sure won't be selling the flail.
/ Let's talk flail mowers #1,039
I would rather keep my flail mower and sell the rotary cutter
If it were me as the brush is not shredded and it will not
degrade quickly.
The other thing is the flailmower will be able to go over it a
second time and shred it much more where the rotary cutter
will simply move it around and beat it down rather than
shred it up a second time.
The only time brush can be hacked well with a rotary cutter
is when it is so dry it breaks in your fingers and that is a
bad time for brush fires.
At least you can mow right down to the sod with a flail mower.
Welcome to another fine member of the "Flail Mower Nation".
"Once you go flail you never go back".:thumbsup::drool:
/ Let's talk flail mowers #1,040
I have both flail and a medium duty bush hog. I like having both. The flail can do most of what I need but I prefer to use the bush hog for heavy brush cutting as it is simpler and cheaper to maintain. The flail can handle the heavy cutting but I lose knives and clevises on rocks often enough ($13 a set) that it is annoying. Also, it is nice to have the cutter eight feet behind the operator station when driving backwards into thick brush as paradoxically I can more easily see what I am cutting than when the flail is three feet back but harder to see over my shoulder. To see where the hog is cutting is a simple glance over the shoulder, to see the flail I need to look over the shoulder and down. If I did yoga it would not be an issue but I'd give the advantage to the hog for backing into brush. The hog is also better for cutting under big blueberry bushes and small trees where low lying branches make it hard to get the flail into position without getting the operator station tangled up in branches.
Other than those examples I prefer the flail for everything else, especially for mowing fields and any mowing near people. The mounted flail fits easily in my barn but I need to dismount either the hog or grapple/bucket to fit the tractor due to the extra five foot extension when the hog is mounted.
I got my Woods Brush Bull 600 used for a great price and even though it is undersized I find it very handy. The cut is nowhere near as good but for first pass I like it in heavy brush or rocky areas with high grass. It is also more ballast by a factor of about two than the flail which is sometimes useful.
I'd keep both.
96" X 20' TRI-AXLE TRAILER (A64280)
96" X 20' TRI-AXLE...
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A63689)
2020 Takeuchi...
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
2022 EZ-GO ELITE...
2010 CATERPILLAR 320DL RR EXCAVATOR (A60429)
2010 CATERPILLAR...
2015 Toyota RAV4 SUV (A61574)
2015 Toyota RAV4...
