Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #7,001
Is that the same as a world famous German company called Deutz?
DEUTZ AG: Engines
Yes it is. Beautiful engines and simple to repair.
The air cooled units can be worked on quickly as
each piston jug can be replaced individually if needed.
It takes time to remove the sheet metal and open up
the engine to expose the jugs and the indirect injection
fuel pump.
In the case of the V-8 engines the injection pump
is located in the valley between the 2 banks of cylinders.
They still have a centrifugal oil filter rotated by the cooling fans hub
that is positioned in the center of the air cooling fans air inlet cowling.
/ Let's talk flail mowers #7,002
"Duetz"
They make beautiful simple to own, operate and use air cooled diesel engines.
I worked on them for years and they are so much easier to repair as they have indirect injection engines.
I went and wandered around tractordata site for dietz. Looks like the unit I got to learn on was one of the 4000 series or maybe toe 5000 series from the 1980's the wierd thing is I thought they had that green beast back in the 70's as well. /Shrugs
/ Let's talk flail mowers #7,003
fuel pump.
Many years ago I had a contract to rebuild some 3 cylinder engines used in fork lifts for a company, they were easy enough to build but as best as I remember they were hard on crankshafts. There was not a single one of them the crankshaft was not worn significantly, enough you could see the journals were out of round. No need to mic them, just take em' to the machine shop. Other than that they seemed like well designed engines.
/ Let's talk flail mowers #7,005
I'm pretty sure the guy who cleared a couple acres of weedy trees for me had one, or one exactly like it.
The first guy came with a $35K Swedish chopper hooked onto the front of his $65K skid steer, very similar but had blades vs. hammers. Nice guy, young, very confident. Within 1 hour he had broken a blade and ripped off the QA metal strap where the big pin locates and left, I jammed $200 in his hand. My new guys says the blades are a big expensive problem.
If they don't take the stump down to grade or just below, you end up with these fuzzy short posts sticking up.
/ Let's talk flail mowers #7,006
/ Let's talk flail mowers #7,007
That's a forestry shredder. It has solid mounted carbide teeth similar to a stump grinder. You can get SSQA and 3-point versions of it. But good luck mowing any grass mowing with that. Turning trees to dust is the sole purpose of those things.
That thing is so cool.
/ Let's talk flail mowers #7,008
Got to see two Bobcat Skid Steer mounted Fecon forestry mulchers in action clearing the pipeline right-of-way. They’re incredible machines for sure.
They make quick work of nearly anything in sight. (Except rocks and barbed wire!)
/ Let's talk flail mowers #7,010
That's $49.6K PLUS the skid steer , right ? All this makes me wonder what the going rate is for hiring such a machine, with operator, to clear land per acre , say in the Eastern USA ? Would it compete with a medium sized dozer? Probably so. After all the dust settles can I bush hog over what is left ? With the price tag on the machine it might be attractive to just hire it done if you have a worst-case section to clear on cleaning up an old farm.
/ Let's talk flail mowers #7,011
Yes it says to SUIT a skid/steer. I have quite a few heaps that need to be cleaned up as well as a lot of brush/trees.
There are a couple of businesses that operate those not far from here but I haven't followed it up.
/ Let's talk flail mowers #7,012
Got quoted $135/hr from the guy cleaning up the farm next door. Yes, ready to bushog/mow when he was done. Fantastic for making trails. The hrs/ac would depend on what is being cleaned up. Stumps go away quick if not in rocky ground. About the same $/hr as a medium dozer around here (middle TN). But no stump or brish piles to deal with, just wood chip mulch.
/ Let's talk flail mowers #7,013
How long ago was that? I was paying more for equipment rental 15 years ago. Typically, it's NOT going to be cheaper than renting the equipment and doing something yourself. Check around. I'd pay more than that to cut my grass. ;)
/ Let's talk flail mowers #7,014
There is place near where I live that they ran one of those Forestry Mulchers on and less than six months later you could not tell it ever was forest it just looked like grass had been there always.
/ Let's talk flail mowers #7,015
A good Forestry Mulcher operator will go back and "back drag" the area to chop everything up even finer .. resulting in even faster decomposition.
/ Let's talk flail mowers #7,016
Within the last year.
/ Let's talk flail mowers #7,017
They're typically tungsten carbide teeth which do not dull easily. They will chip and break on rocks, but dirt usually doesn't phase them. It's similar to stump grinder teeth, those don't go dull quickly in dirt either. I have a carbide chain for one of my chainsaws and I can cut dirt with it while cutting a tree at ground level and it stays sharp. And the saw chain would be far more susceptible to dulling than the teeth on the forestry mulcher. Sharpening the carbide teeth is another thing. You need diamond grinders to sharpen anything carbide.
To put the abrasion resistance of tungsten carbide into perspective: we use tungsten carbide to cut hardened steel. We cut abrasion resistant steels (D2 for those who know steel) up to 60Rc hardness with carbide cutters, but typically they're dull after a few cuts. A36 is easily cut with carbide endmills with hardly any dulling after several cuts. Tungsten carbide is, however, brittle. If you strike a rock with the tooth it will chip or shatter, depending on the strike. I can take a hammer and shatter a carbide endmill easily. Typically if an endmill is dropped the tips are broken off.
/ Let's talk flail mowers #7,018
Thank you for that comprehensive answer. Really appreciated. I do have rocks on my property but they are mostly a softer sandstone type but they still play heck with my flail mower. I usually run it a bit higher to avoid rocks and sticks.
OK on the chainsaw blade. I am aware of how quick they go blunt if you hit the dirt. Caught too many times.
/ Let's talk flail mowers #7,019
Regarding this whole thread and buying a Flail. Question, there is a Titan Implements company in Tn. that makes GRAY implements reportedly in the US. Then there is a Titan that makes red attachments from China. Are these two different companies of different origin? I like what I see of the Gray Flail Mower from Tn. As a newby I have read most of it. My PTO HP is around 56, Eng 67. Any comments please.
/ Let's talk flail mowers #7,020
We sell the gray ones built in India for Titan out of TN. If you happen to be in Northern California, I have a dozen or so of those flails in stock. Heavier duty by far than most of what is commonly imported from China. These specs out closer, and look more like, some of the European commercial-grade flails.
2015 FREIGHTLINER CASCADIA 6x4 T/A DAY CAB TRUCK TRACTOR (A59906)
2015 FREIGHTLINER...
1991 FRUEHAUF 45'X96" FLATBED TRAILER (A65643)
1991 FRUEHAUF...
Manure spreader for sale / Excellent Condition / Make offer
Manure spreader...
New/Unused Wolverine Quick Attach Coupler (A65583)
New/Unused...
New/Unused Landhonor 78in Rock Bucket with Teeth (A65583)
New/Unused...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2018 Ford F-150...
