Let's see your welds...
/ Let's see your welds...
Any more photos of your weld photos? This thread has had over 9300 hits and that shows people want to see weld photos. Probably to compare their work. Any weld photos welcome.
/ Let's see your welds... #122
Here are the hooks I put on the Kioti bucket.. better than the factory Mig welds on the pads in my opinion.
James K0UA
/ Let's see your welds... #123
Awsome man, they aint going nowhere. Good work bud!
/ Let's see your welds... #124
Miller Thunderbolt AC/DC welder scratch start tig photo's of stainless.
Millermatic 185 mig welder. 3/8" plate steel- ER70s-6
welds 001.JPGwelds 004.JPGwelds 005.JPGwelds 006.JPGwelds 009.JPGwelds 011.JPG
/ Let's see your welds... #125
/ Let's see your welds... #126
Any details on the thunderbolt scratch setup? I have the same welder and have been contimplating doing this. Thanks!
Very simple set-up
1 Argon tank for shielding gas
1 Tig torch with collet to hold tungsten electrode. 3/32" electrode is a good choice.
1 conductive tig torch hose to connect to torch.
These can be bought as a kit.
Check EBAY and they are usually found for a low price.
1 bulkhead connector to join the torch hose to the shielding gas hose.
1 piece of non-conductive hose to supply shielding gas to bulkhead.
DC polarity is the set-up for carbon steel and stainless steel.
Negative lead to electrode holder which is clamped to the bulkhead and makes the torch negative.
Posative to the ground clamp.
Turn on argon
A scratch start gets the arc going.
Feed or dip your filer rod and work the weld puddle with your torch.
A flick lift of the torch to stop the arc. You must return the torch to the weld momentarily to provide argon until the weld puddle cools for a few seconds.
Stopping requires a little practice so you don't restart the arc for the post flow of argon during cooling.
You'll catch on.
Adjust your heat as normal.
I can give you tips on grinding or sharpening the tungsten later if you wish.
The second purge is basically for stainless.
when welding stainless, usually it require a purge on the back side of the weld. thinner material stainles will suger out if oxygen is present in the weld.
A black crusty deformation is a way to explain what it looks like.
Stainless pipe is usually pluged with a rubber or lead cork with a hole in the center of the cork.
A tube with the argon is fed thru the hole in the cork.
the other end of the pipe is plugged lightly with a piece of steel wool.
turn the second purge on before you start to weld and purge the inside of the stainless pipe to remove oxygen.
A piece of fiberglass welding blanket can be put on the back side of the weld to stop oxygen from comming in contact with the weld area also.
copper plate will work too.
If you have questions don't hesitate to ask.
/ Let's see your welds... #127
And when you get it figured out and start making some pretty good welds, is when you start wishing for HF start, and a foot pedal to adjust your heat, and to taper off with instead of snapping out at the end. I know I do.:)
James K0UA
/ Let's see your welds... #128
James K0UA
Right!
That's one of those items the wife keeps saying " it's not on the priority list".
I wonder what my next wife will look like ?
:confused3:
/ Let's see your welds... #129
James K0UA
It just never ends, best to never get started I guess! :D
/ Let's see your welds... #131
Here's my thee point carryall project that I put together to move stuff around in the yard with my BX
/ Let's see your welds... #132
Can anyone comment on a comparison between the Millermatic 211 and Lincoln 216? I've been thinking of a Lincoln but lots of guys like the Miller and I just don't know enough about them.
I used a 216 a friend bought new. Seemed like a smooth running machine. It did everything I wanted to do. Welded 1/2 in single pass. The only thing is. It's a tap machine, which means you can't dial the machine into exactly where you want it. Other than that it's a good machine. I would buy it over the 211.
/ Let's see your welds... #133
A Gas Tank made from 304 grade Stainless Steel / Tig Welding.
/ Let's see your welds... #136
Miller 210, .035" Lincoln L56 wire, 75/25 gas:
After spatter removal, media-blasting, primer and JD Green paint:
/ Let's see your welds... #139
Are you kidding! He would be the lead welder! :)
ok Guys try and welding tig up side down and havinig it x rayed thats what you have to do on power plants not bech welding
/ Let's see your welds... #140
If you saw factory welds on a tractor you would know I was kidding!
2023 Boxer 700HDX Compact Skid Steer (A63109)
2023 Boxer 700HDX...
2012 INTERNATIONAL LA677 4X2 S/A DAY CAB TRUCK (A59911)
2012 INTERNATIONAL...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
2017 Xtreme Telescopic Telehandler (A60352)
2017 Xtreme...
Massey Ferguson 4710 (A60462)
Massey Ferguson...
2017 CATERPILLAR 980M WHEEL LOADER (A64279)
2017 CATERPILLAR...
