MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 67,359
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
I was the Nuclear, Biological and Chemical Warfare officer for my unit. Nuclear EMP can effect equipment a long way away - but if one goes off, more will probably go off. If that happens EMP is likely to be of small concern.I wonder if EMP considerations are worthwhile. Many Military Surplus Gensets on E-Bay are EMP shielded. But then, after an EMP event, you may not have anything left working anyway.
I think a lot of you are over-worrying about storing gasoline and water. While it is a real problem, it can be virtually eliminated by rotating your stock and using a filter/water separator.
Anyone remember these?
I understand your point and agree but I also think there is a big difference between water and fuel...
Just using Katrina as an example...for those in despair...other than working (sanitary) facilities...drinking water was the most coveted thing...populations that rely solely on public water systems could have a hard time with nothing more than a sustained power outage...water is much more important than fuel...but they're connected if water has to be boiled before consumed and for whatever reason there is no electricity for a long period...it could get very bad very quickly....IMO.
You can survive several months without food, only several days without clean water. Drinking water that'll make you sick is even worse. Gallon jugs are good , but tend to leak, especially if sat on concrete. Also you don't want to eat if you don't have clean water to drink. Water heaters and water bobs for bathtub can be a good emergency water source. 55 gal food grade barrels and 275 gal cage totes are better. Lexingtoncontainer.com is a good place to see what's available.
As far as fuel we have 1000 gal propane, 300 gal non ethanol gas & 100 gal diesel on hand. These are used constantly and replenished at about 50%. Gas/ propane generators, Agm battery banks & solar panels are always at the ready JIC.
I like propane. We keep 3 five hundred gallon tanks, two always kept in reserve, plus dozen 100lb bottles (23gal ea). Plenty of fuel, as above. Grid electric is backed up by 11kw solar with AGM battery bank.
Water, we have two sources. A gravity fed spring that we've used for 30+ years, with 3,000 gallons of storage. A drilled well with submersible pump as a backup to the spring.
Both feed into a utility room in the basement. By switching valves, we can run off either. Recently put a booster pump on the spring line as the gravity feed only gives 25psi (which we lived with for 30 years). Now the house pressure is 55-75psi....a vast improvement. Ran the lines so we can still bypass the pump and use the gravity spring directly as well.
Everything runs thru a screen filter, then a 5 micron whole house filter, then a UV sterilizer light.
Man, that is a nice setup.
I have a similar spring fed well, that would feed the house by gravity, but always wrestled with the time and cost associated with burying a line a few hundred feet to connect to it.
