Leinbach PHD?
/ Leinbach PHD? #1
snal
NC
Kubota BX24
Local implement guy has these for $375 incl. 9" or 12" auger. Looks like a good price....Is there anything specific that I need to check to make sure It'll fit my BX24?
Thanks!
/ Leinbach PHD? #2
My Leinbach 12" has survived a long time despite my tender mercies - like driving it with a 60 hp tractor. I don't know about fitting to the BX but I can vouch for Leinbach PHD durability. I've wiped off lots of drive bolts and even the thick plate that the gearbox hangs from has been twisted on my rig - but the gearbox itself has held up just fine. $375 is dirt cheap if it is the same animal.
/ Leinbach PHD? #3
As much as I cussed mine, especially after it breaks shear bolts everytime I spin it, I have to admit that the gear box is pretty tough. To save time in the field, I swapped form grade 2 to grade 5 shear bolts. /forums/images/graemlins/shocked.gif At the time I didn't care if I destroyed it. I was sick of changing the bolts!!! /forums/images/graemlins/mad.gif Anyway, I've now broken off several grade 5 shear bolts with no damage to the gear box. I did actually twist a 12" auger in half with it though. /forums/images/graemlins/blush.gif
/ Leinbach PHD? #4
Hi Snal,
You may want to pickup the Pat's easy change, this will increase the lift....BX 3PT cannot go as high as the bigger guys. Maximum digging deep may be 3 1/2'.
Bird
/ Leinbach PHD? #5
It's also probably a good time to re-link Charliebrn's 3PH mod.
I actually drilled 2 sets of holes at 3/4" and 1.5" for a little more flexibility.
They make 42" and 36" augers as well, as an alternate route, if needed.
Cheers!
/ Leinbach PHD? #6
Leinbach makes a couple of different models. If memory serves me there was a 7300 or 7200 model for the subcompacts. Ask the guy which model it is.
I have a 7400 which fits on my B7510 okay, also fit my jinma. It works like you wouldn't believe, but you may break a sheer pin or two. I actually have stopped the auger in rock and it didn't break, dropped the lift by accident while driving and it broke. These things are heavy as heck so be prepared...my back will never be the same.
Mow
/ Leinbach PHD? #7
They also make a 7200jr that fits my bx great.
72in. Fork Extension (A64553)
72in. Fork...
2013 International DuraStar 4300 General Cable T40-C 35ft. Bucket Truck (A64194)
2013 International...
UNUSED FUTURE CAT 303-46" EXCAVATOR RAKE (A65055)
UNUSED FUTURE CAT...
2013 Ford F-150 Crew Cab Pickup Truck (A64556)
2013 Ford F-150...
2018 FREIGHTLINER M2106 DUMP TRUCK (A63276)
2018 FREIGHTLINER...
2014 Chevrolet Impala Sedan (A64557)
2014 Chevrolet...
